Cummins isx continues to run after key off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JustinofPeteNYC, Apr 25, 2013.
  1. JustinofPeteNYC
    JustinofPeteNYC Bobtail Member
    40
    Feb 26, 2013
    Shut the key off and the engine will stumble for maybe 10 seconds. Anyone come across this? I narrowed it down to injectors 1,2 and 3. I disconnected the fuel control valve for them and ran the truck and shut it off and it shut right down. Anyone have much experience with this? Almost positive it's the 3 injectors but just looking for some input.
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    It's the fuel shut off solenoid in the middle of the rail take apart clean the spring and disks inside the house change o rings and put back it will shut off right away I've ran across this maybe 30 times its always same thing
  4. JustinofPeteNYC
    40
    Feb 26, 2013
    Customer already changed the shut off valve. That was my first idea but then found out it was changed
  5. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    He changed the solenoid or the actuall valves inside.
  6. JustinofPeteNYC
    40
    Feb 26, 2013
  7. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Did you check if the power is shutting off to the solenoid when you turn the key off or if the truck shuts down if you remove the power wire.
  8. JustinofPeteNYC
    40
    Feb 26, 2013
    I did check for power after key off to shut off valve and there was none but I should disconnect it while running and see what happens. Still think I got an injector or two leaking down into the cylinder
  9. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Remove power and it should shut off right as you remove it
  10. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    [HR][/HR]Can be the timing or fuel actuatators there are four of them the shut off selinoid is in the middle two front are fuel and timing for the front 3 cyl the rear 2 are fuel and timing for the back 3 cyl also check the internal parts of the fuel selnoid for burs and debris also make sure the mounting screws have a good connection as thats how it has its ground
  11. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    the customer changing the solenoid himself may be the problem.as all of us "professionals"know it is very easy to put the solenoid parts back together wrong.triple check.good luck.
