cummins isx belt tensioner.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Edgar2191, May 18, 2014.
  1. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    my main serpentine belt is going bad stripping pieces. Should i replace the tensioner while on at it? The truck just hit 600k miles is that normal for a belt to last that long? Last question to loosen the belt i have to loosen the belt tensioner right and when i put the new one tighting it and that its nothing else gets moved?
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yep, the tensioner will have a 1/2" square drive in it so you can pull it (or push it) to loosen it with a 1/2" drive ratchet. You got real good life out of that belt!!! Replacement of the tensioner depends. They are spring loaded. When you move it to remove the belt and it does not spring back, time for replacement. Once your belt is off, spin the roller by hand. If it doesn't not spin smoothly, or you can hear funny noises, the bearing is worn and time for replacement. If you want to do some preventative maintenance, now would be a good time to replace it anyway.
    JonJon78 Thanks this.
  4. AnneK
    AnneK Bobtail Member
    41
    6
    Apr 30, 2014
    I don't know what year you have, but my Cummins has a 3/4" square drive on the right side main belt and a 1/2" square drive on the left side A/C belt. It is not normal for a belt to last 600K - are you the original owner? If not, it most certainly has been replaced before by a prior owner, if you are, and the belt really made it that long, that's pretty much the longest lived belt I've ever heard of in my life. Tensioners can have several problems. As mentioned before, the bearings can go up in them which causes noise and a wobble. The tension spring can also wear out, which causes loss of tension on the belt and allows it to slip over the side of the pullies and get torn up by the pullies themselves. They recommend a tension gauge to check this, but myself and everyone else I know does a pull and twist on the belt to make sure it is not turning more than about 90 deg. It is not a bad idea to replace it at 600K if it is original because it's probably at the end of it's life and you have to install the new belt to really check it anyway (and when it fails, it will likely take your belt with it). The other things that can cause belt failure are bearing failure in other pullies including idler pullies, alternator, A/C, PS, anything that is belt driven on the system. Again look for noise and wobble to determine this. If you want to diagnose before you do anything else, get your new belt and install it and inspect the other pullies from there.
    bigNATURE Thanks this.
  5. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Wow, that's incredible for sure if that's original belt. My '06 I was replacing pretty much once a year, it would start squealing and chirping when it was time.
  6. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    I think Id replace it anyway. Then youll know its new. I had a belt do that. the first Volvo shop said the tensioner was ok but I got about a 1000 miles down the road and it shredded that new belt. The people at the second Volvo shop said the first should have replaced the tensioner because that's the only thing that shreds a belt like that. They replaced it and I didn't have anymore problems with belts.
  7. slippez
    slippez Bobtail Member
    22
    4
    Apr 13, 2014
    get the cummins # and cross it to gates, dayco, or goodyear and save a 100 buck while your at it
  8. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    I think I'd replace the tensioner and pulley as preventative maintenance and check the alternator, fan, and AC clutch bearings while you have the belt off. I've seen several trucks crank slow and refuse to start because of seized AC clutch bearings. Cheaper to check it while you're in there, and repair as necessary.
    Heavyd Thanks this.
  9. barnmonkey
    barnmonkey Bobtail Member
    41
    30
    Jul 3, 2008
    Central, MD
    I have a 04 CM870 ISX in a 2004 International 9400i.
    When I replaced the tensioner last year I used the new bolt that came with the new tensioner. LARGE MISTAKE!!!
    It was shorter then the original and didn't torque down correctly and tried to strip.
    Apparently, they use this tensioner in other applications where a shorter bolt can be used, NOT the ISX
    All in all not a hard job to do with basic tools.
    Best of luck
  10. mike216
    mike216 Bobtail Member
    44
    13
    Dec 15, 2013
    Cordova,Md
    Has anyone had trouble with the threads stripping out of the bracket that holds the air conditioner tensioner? If so what is the fix?
