Cummins ISX belt squeal
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lilillill, Mar 3, 2011.
  1. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    After the shop changed the idler and belt on my truck, the belt squeals whenever the fan engages. The routing appears to be correct except for the fact that the belt only contacts about 1/4 of the fan pulley--from 12 o'clock to 3 o'clock. This wouldn't seem to me to be enough to keep the belt from slipping.
    Can someone snap me a pic of your ISX belt routing and post it here please.
  3. lilillill
    5,642
    13,470
    Nov 7, 2007
    Here is the current routing...
  4. Gambi80
    Gambi80 Medium Load Member
    All you need is a short vid doing your best impression of John Madden descibing your problem. lol. Sorry, couldn't resist.
    stayinback and lilillill Thank this.
  5. lilillill
    5,642
    13,470
    Nov 7, 2007
    Problem solved.
    Gates belts do not have enough grip. Installed an OEM Volvo belt... no more squeal.
    :yes2557:
  6. bossboy2
    bossboy2 Light Load Member
    264
    59
    Aug 20, 2011
    Houston, TX
    Weird, I've had several mechanics tell me it's my belt. Now I have three (belts), all idlers and tensioner have been replaced, alternator had new bearings installed...I give up. I have to nose in at truck stops so I don't annoy the other drivers while they're sleeping. Once the part finally fails I'll replace it. Not spending any more on it.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    I have learned recently that if the pulleys get dirt in the groves it will let the belt slip on a serpentine belt took an ice pick and cleaned the groves, no more sliping until they fill with dirt again.
    Heavyd Thanks this.
  8. Dipsomaniac
    Dipsomaniac Bobtail Member
    26
    Aug 14, 2013
    Ventura, Comiefornia
    Paraffin or surf board wax applied to both sides of the belt will shut them up sometimes. Apply while running and watch your fingers.
  9. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    how do you release the tension on the smaller belt behind the serpentine one?
  10. Dipsomaniac
    26
    Aug 14, 2013
    My friend Had a converted commercial 32' alum. dive boat with a 360hp cummins and when we would drift and sleep at night with all the electronics and deck lights on on the tuna grounds. When we would start the main engine in the morning our alternator would chirp like a b!tch from the amperage pull to the multiple battery banks. 2 for the main, 1 for the genny, 2 for the house all on isolators.
  11. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I would yank the belts off then clean the pulleys off with mineral spirits and a rag. Using a brush to get in between the grooves would be a good idea.
