Cummins ISX Air Compressor Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JDHIGGINS44, Aug 22, 2016.
  1. serozhah
    serozhah Light Load Member
    283
    45
    Sep 8, 2013
    wow, sounds like iḿ lucky to have never had cummins:) cats seems like the last of the good american engines. Although, I never had paccard engine. Not sure how they compare:)
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    That is not very fair. I believe his ISX has a Wabco compressor but it could be something else. He did not say. Many Macks and other equipment use them. Cummins used to normally use their own compressor and an unloader kit would often fix them. Then changed to Holset. Compressor problems I see most have Cat on the side of them. Pumping oil and even some replacements doing the same thing. One did not build air. It is also not very fair on my part to tell you what I see the most air compressor problems when those are about the only late model trucks around here.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yeah, he didn't say what he has. I think most Hostel compressors are pretty reliable and last a long time.
  5. Bigcsr
    Bigcsr Bobtail Member
    I’m having the same problem, while driving it will stay at 120psi and out of the blue would dropped to 95
