Cummins ISX Air Compressor Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JDHIGGINS44, Aug 22, 2016.
  1. JDHIGGINS44
    JDHIGGINS44 Light Load Member
    112
    262
    Jun 29, 2015
    Waynesburg, PA
    Hello all, I am having a problem with one of trucks air compressor and one of my mechanics found a quick remedy to get us by until we get it in the shop this week. The problem is the truck will not build air after sitting for a weekend or however long it takes until tanks are near empty. You can start it up and run it as long as you want but it will not build an ounce of air. Now take off the small air line nearest the frame rail "the one that is easily accesible" and put a small handheld vacuum pump on the compressor side and a simple 1 or 2 pumps and the compressor kicks in and works flawlessly for as long as you wish until the truck sits and tanks empty again. Any ideas or help would be greatly appreciated. By the way 2013 Kenworth T800 550HP Cummins ISX15
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Usually carbon build up in the compressor head and the unloader mechanism sticks. A few taps with a hammer usually gets it going again.
    serozhah and KeithT1967 Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
  5. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Cummins has procedure for the air compressor valve unloader cleaning.
    Air pressure should be drained to ZERO.
    Disconnect both sides of compressor and air pressure governor tube.
    Spray liberal amount of WD40 into air pressure governor .
    Put some rug over compressor discharge opening .
    Safety glasses is ON !!!!!!!!!!!!
    Start engine and spray WD-40 into pumping compressor until carbon deposits are washed from the valve.
    serozhah and blr300 Thank this.
  6. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Sounds like the issue I had last year. In my case it didn't have to go all the way to zero. I'd start the truck in the morning and it wouldn't start building pressure till the truck ran for 10 or so minutes in high idle. After reading about the unloader valve carbon problem I tried tapping the compressor head with a hammer while doing my pretrip. Worked every time. Ended up replacing the compressor.
    bzinger and serozhah Thank this.
  7. JDHIGGINS44
    112
    262
    Jun 29, 2015
    Waynesburg, PA
    Alright thanks a lot everyone, I'll try cleaning the unloader and go from there if not it's a new compressor supposedly they don't make rebuild kits for these ones.
  8. blr300
    blr300 Light Load Member
    76
    30
    Jan 5, 2014
    St. Thomas Ont. Canada
    That worked for me as well a couple years back.
    Snailexpress Thanks this.
  9. serozhah
    serozhah Light Load Member
    283
    45
    Sep 8, 2013
    would replacing unloader valves with the unloader kit solve this problem?
  10. serozhah
    283
    45
    Sep 8, 2013
    seems like 40 dollar unloader valve kit would have solved your problem? I thought you only replace compressor if its pumping oil?
  11. Heavyd
    7,749
    6,184
    Feb 4, 2009
    The compressor for an ISX doesn't really have the same unloader mechanism that Bendix Tuflow model has. You just replace the whole head unit on an ISX compressor.
    serozhah and BoxCarKidd Thank this.
