Cummins ISX 450
Discussion in 'Trucks [ Eighteen Wheelers ]' started by justruck1, Jul 18, 2010.
  1. justruck1
    justruck1 Bobtail Member
    16
    Jul 17, 2010
    I just bought an 06 Pete with an ISX 450 that has supposedly been turned up to 500. I also own a Pete with a Cat 3406E 500 hp, the Cat will out pull the Cummins by double. Same trans and ratios. The ISX is only producing about 28 - 30 lbs of boost, the engine oil gets real hot, up near the red line when it's working. Can anyone tell me firstly, can a 450 be turned up to 500 HP and what should the boost pressure max out at when it's pulling
  3. dogface
    dogface Bobtail Member
    23
    4
    Jun 19, 2010
    hello,justtruck1 I would have to say it is stock .I had the same problems with Freightliner trucks lieing to me about the H.P. . they paid 3000 to keep the truckpaper people from pulling them if they did not make it right. I have a fld120 2001 w/isx450 that makes the same 24-27ish lbs boost . a 500 is 29-34 I belive is what was quoted. there is a place called J Ball in B.C. that can help you more ...I am going to have cummins reflash my E C M to 600 for 300 clams ,and will be careful on E G T and boost
    justruck1 Thanks this.
  4. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    One of our trucks is a 2004 Volvo with a 450ISX and the boost goes up to 35psi. This is stock setting.
  5. dogface
    23
    4
    Jun 19, 2010
    35 boost is not 450hp there ..you must be in the 500+ or so ?? but you have a emissions engine there don`t know about them
  6. mrdevildog
    mrdevildog Light Load Member
    75
    22
    Feb 23, 2010
    Heber Springs, Arkansas
    the only way to know what the spec is is to get it from cummins or someone who has access to the cummins website based on the engine serial number, also low fuel pressure equeals low boost pressure, its over looked more than you think.
