hello, we have a 2015 isl 8.9 and it randomly died and now wont start back up. fuel tank was about 25% full and we filled it to the top. replaced both fuel filters. Opened up the fuel link going to the fuel pump and there is alot of fuel coming out when we cycle but then we opened up the injector rail line and there is no fuel coming out from there even when we crank? So seems like fuel is going into the fuel pump but nothing is coming out? anybody know what would cause that to happen?
cummins isl 8.9 died and now wont start?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mixingconcrete, Mar 23, 2022.
Failed fuel pressure regulator?
I would suggest using QSOL and TS engine cranks but will not start. You could toss parts til the cows come home.
Faults logged upon hook up? 559?AModelCat and spsauerland Thank this. -
baha Thanks this.
Figured it out by just spraying some starting fluid while cranking. I guess had a lot of air in the system. The auto fuel primer pump when turning the ignition on didnt help at all because we cycled the ignition probably like 80+ times lol. I almost never use starting fluid but this time i was running out of options and we needed this truck asap. -
Air gets trapped in the common-rail and acts like a cushion that the pump cannot overcome.
Crack the high pressure line from the HP pump to the rail. Loosen the line at the common-rail. The nut has a relief cut in it to the fuel does not spray toward you. Crank the engine until fuel comes out and then retorque the line- Should fire off shortly after.spsauerland, AModelCat and stuckinthemud Thank this.
