what is MID 28 PID 391 FMI 11? Is it regen related? Driver said "check" keeps coming on, but the truck is running fine. Thank you.
Cummins engine code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DZM82, Apr 13, 2017.
You will not be able to regen with this code active.
This fault code becomes active when the aftertreatment diesel oxidation catalyst inlet and aftertreatment diesel particulate filter inlet temperature sensors do not detect the presence of a catalyst in the aftertreatment system. This can be caused by tampering with the catalyst system, the catalyst has been removed from the vehicle, or a damaged catalyst
CODE REASON EFFECT
Fault Code: 1664
PID: S380
SPN: 3050
FMI: 11
LAMP: Amber
SRT:
Catalyst Missing - Condition Exists. The aftertreatment catalyst in the exhaust system is not present.
Active aftertreatment diesel particulate filter regeneration will be disabledDZM82 Thanks this. -
That has to do with the EGR pressure differential sensor, most likely the tubes are clogged. Pull the tubes off the sensor, if they are blocked, clean them out really good. Some of them are really hard to clean out and easier to just replace.
SAR, EZ Money, Heavyd and 1 other person Thank this. -
If he keeps going, at some point the dreaded red shutdown light will appear and he'll be screwed. Besides what GrapeApe says I'd get it to a shop in short order and plug into it.
And the EGR differential pressure sensor has nothing to do with this error. It's a Catalyst err. It's not spraying into the exhaust properly. Usually a bad sensor in the tank.
Fault Code: 2774
PID: S391
SPN: 3058
FMI: 11/31
LAMP: Amber
SRT:
Exhaust Gas Recirculation (EGR) System - Condition Exists. Plugged EGR differential pressure sensor tubes have been detected.
Action Taken When the Fault Code is Active:
- The ECM illuminates the amber CHECK ENGINE light immediately when the diagnostic runs and fails.
- EGR valve operation will be disabled.
- A plugged or leaking low or high EGR differential pressure tube
- Carbon buildup inside the EGR venturi tube blocking the opening to the EGR differential pressure tubes.
Heavyd Thanks this. -
