I have a 1998 M11 that I have been driving for several years now. Many years ago I had the local KW dealer set my speed limiter to 65 mph and set up driver rewards so I have a little more control. All was good until last Friday....... My truck won't go over 63 mph. I took it o another KW dealer and they hooked up the onsite laptop and it looks like driver rewards is set to 3.5 mpg. Im pretty sure I'm getting better then that. Why is my truck governed now?
cummins celect + driver rewards
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, Feb 14, 2015.
What are the idle standards set at? Also, when the speed reward is programmed in, there's also a line for "Penalty"... was that value filled in?
Why not just turn it off if your the driver?
Cetane+ Thanks this. -
Idle standards 50% if I was reading it correctly (looking over the "tech's" shoulder). -
rank Thanks this.
I called Cummins today to buy a copy of "Insite". They told me not to waste my money and download "powerspec" instead. Free download all I have do to is buy the $700 cord.
Powerspec is good to have... I'd recommend getting a NexIQ connector over Inline 6, since you can use NexIQ to diagnose ABS issues, as well.
Aside from fuel mileage, there's also idle time criteria which can be set for Driver Rewards, as well.
Penalty will be in the same drop down menu as the 'best/expected/good' speed reward settings are.rank Thanks this. -
Excellent info here. Thanks Witching hour.
Does Powerspec let me change the tune, do a cylinder cut out and monitor the injectors while driving to see if I have a bad injector under load?Last edited: Feb 17, 2015
