Cummins air compressor question.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by custm2500, May 14, 2013.
  1. custm2500
    custm2500 Bobtail Member
    12
    I have a 90something ford with a cummins. The air system is getting a ton of oil in it. My guess is the oil seems to skim off the top end of the engine to lube the compressor. Does it make sense that they oil passages in the engine are clogged and keeping too much oil in the top end, thus flooding the compressor?
    Thanks for the help.
  3. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Most modern air compressors get their air intake from either the air cleaner housing or piping, or from the intake manifold of the engine. Older compressors had their own little air filter and intake. When you have oil in the air system, your compressor is passing oil some how. It could be from a restricted air intake and sucking some oil through its own rings, but the most likely problem is a worn out compressor and oil is simply getting past the rings.
    cetanediesel Thanks this.
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Try replacing the air filter for the compressor first, maybe you'll get lucky.:)
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Try replacing the air compressor probably worn out if you have a clogged oil passage you're engine would have blow up or locked up by now if its not getting enough oil to bottom end
  6. custm2500
    12
    The intake for the compressor seems to go into the valve cover. There is a short piece of rubber hose that mounts the two hard lines. It is soaked around the edges like too much oil is there and then the tanks dump oil when out of the pressure relief. I don't really want to replace a compressor till it is more solified that is the problem. Maybe there is simply a baffle that doesn't allow as much oil down the tube.
  7. custm2500
    12
    I came to the forum for expertise and that is what I got. The compressor is shot and I ordered one today! Thanks for your help. How complicated is this job? Seems easy but my only concern is the fuel pump is behind the compressor. Is this the high pressure pump and is there anyway I will mess up the timing of the engine? Or is the shaft splined to only fit one way?
    Thanks again!
  8. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    That pump has a spider in between its a small plastic wheel looks like a small gear with 6 big teeth make sure you put it back and the fuel pump sits properly its bit that hard to remove also make sure the compressor goes in easy and don't pull it in with the bolts whatever you do cu you can do some serious damage to the gears if not lined up properly.
  9. custm2500
    12
    Thanks. So a plastic bushing on the fuel pump and it should slide togather like a driclveshaft. Smooth.
  10. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    It's not a bushing it's a coupler it matches up the back of the compressor to the fuel pump splines
  11. custm2500
    12
    The compressor came in yesterday so I will be swapping this out when I get to work today. Seems simple enough!
