Cummins 400 big cam
Discussion in 'Ask An Owner Operator' started by smugglinggoods, Aug 29, 2010.
  1. smugglinggoods
    smugglinggoods Light Load Member
    108
    26
    Jul 22, 2010
    Finally got to fix my tach today thought I had a bad cable so went and bought a new cable. That didnt fix it so i bought a new tach. Installed it and upon running truck it says I am idlling at 300rpm. So took it out and see it says 1:1 ratio on it. So my question is what should I idle at and can I just time the 300 buy 2 or 3 to get the right numbers. I hate to waste time taking it bakc and trying to get a new one. I live several hours from the place I bought it at. What do you all think
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Is there a ratio adapter at the pump or the end of the cable at the tach? If so, try removing it and connect the cable direct.
  4. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    maybe the engine IS idling at 300 rpm.
  5. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    if you don't have it idled up a bigcam can idle 300 to 400 rpm.
    there is an adjustment screw that can be used to set it higher but I forget where it is now. I've tried to scrub every memory of them POS motors from my brain
  6. stranger
    3,640
    4,959
    Oct 10, 2006
    NC
    On the old style pump it was inside the plug at the rear of the pump. The screw was in the removeable cover where you put the shims in at. Just remove the plug and use a straight blade screwdriver.
    See arrow in picture.
  7. 359kool
    359kool Light Load Member
    188
    119
    Jun 18, 2009
    alabama
    Give the guy some credit...... he wants to use a simple "formula" to figure his rpm because he bought the wrong tach...... don't really know why anyone would want to do that but....... don't expect any "formula" can be figured without knowing what ratio the correct tach should be though..
    But to suggest that he adjust the low idle screw on his motor to correct a wrong ratio tach is loco..... :biggrin_25523:
  8. stranger
    3,640
    4,959
    Oct 10, 2006
    NC
    Why do you think his tach has the wrong ratio? It could be right or wrong. I merely stated how to set the idle IF it turns out the engine is really idling at 300. When idling that low, there is usually a lot of transmission rattle and truck vibration.
  9. smugglinggoods
    108
    26
    Jul 22, 2010
    Well the engine runs and idles fine. I just assumed it was suppose to idle higher then 300 there for figured my tach ratio is wrong. Rather then drive to get a new one which is a 3 hr drive I thought I could calculate a new ratio. What should this engine idle at and what is the rpm range? Maybe this will help me out
  10. stranger
    3,640
    4,959
    Oct 10, 2006
    NC
    It should flat foot, no load, at around 2150-2200, unless it is a formula engine, then 1900.
  11. Krooser
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    IIRC most of the one's i drove were set at around 450 rpm's...
