Cummings isx catalyst dosing unit
Discussion in 'Peterbilt Forum' started by Rooster1291979, Apr 13, 2014.
  1. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    2012 389 with the cummings isx. Showing a catalyst dosing unit fault. Any idea on what could be causing this, severity of problem; ie.. Get it looked at NOW, or when you get a minute.
  3. biggare1980
    biggare1980 Medium Load Member
    344
    192
    Apr 29, 2009
    Springfield, Ohio
    If it were me I'd get it looked at now, putting it off could leave you with a tow bill if that thing desides to derate or shut down completely. Sounds like it could be the doser valve going bad.
    Rooster1291979 Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    What fault it it? They sell a kit, which is just some gaskets and bolts, to service the dosing unit. They clog up and should be pulled off once in a while and cleaned out. We did a 2012 last week that was not having any problems, just routine maintenance, but when I got it off, I was amazed that it was even working. The hole is about 3/8", but was clogged down to less than 1/16". It took a pick to get the dried DEF off and I use a brass wire brush to clean out the doser head.
    After seeing that, we changed that scedule to an annual rather than bi-annual. There is also a DEF filter that is easy to change.
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    What is a Cummings? That's your first problem, misidentifying your engine.
  6. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    The DEF doser? It's not a difficult thing to service, but it is sort of a pain in the ###, unless you have a short enough sleeper that you could lay on the catwalk and get to it. It'll be similar to the dosing injector on the engine, except the insulator will be smaller, and you'll probably need a small chisel to get it out of there, and make sure you clean it out well. Two bolts, a gasket, and an insulator... one thing Cummins definitely got right was these dosing injectors.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    You must have a different setup than our 389's. On ours, you just slide under the right side step and it's right there out in the open. 2 V-bands clamps will take the whole pipe off so you can work on it on the bench.
  8. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    We must. On our T660s and T800s (haven't serviced one on a 680, Volvo, or PornStar yet), it's located above and slightly left of the driveshaft.
  9. Bigdawg69
    Bigdawg69 Bobtail Member
    17
    8
    Sep 17, 2014
    Same for the paccar engine since it's also the Cummins emissions on it. My smartnav says I got that problem to. The spn3361 but when the shop plugs in Davies dissent show no codes for it.
