Cruise Control works sometimes, 1994 W900L with Detroit
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bean Jr., Nov 26, 2017.
  1. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,699
    Mar 30, 2014
    1994 W900L with Detroit, sometimes the cruise control will engage, most times it won't. Most times, fast idle will engage, but not always. Help!
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Check clutch and or brake pedal sticking or not fully coming up all the way is the most common issue. Make sure the pivots and linkages are free. If you get it to not work try pulling up on the pedals. Next most likely suspect is either switch sticking contacts clutch or brake switch.
    HTH
    Oxbow Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    To make fast idle work, switch must be on, hit set or accel switch, park brake must be set, clutch and brake switch are ignored.
    For cruise, switch must be on, hit set or accel, park brake released, service brake released, clutch switch applied.
    Common switch for both situation problems is the actual on/off switch and the actual set switch.
    Bean Jr. Thanks this.
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    I agree with you also have found the switch loose on the frame
  6. Oxbow
    Oxbow Road Train Member
    12,480
    128,189
    Nov 24, 2015
    I had the same problem recently with a Cat. It was the on/off switch in dash.
  7. Bean Jr.
    5,468
    9,699
    Mar 30, 2014
    I'll rule out power switch and get back to you.
    Oxbow Thanks this.
  8. goldwing-rider
    goldwing-rider Bobtail Member
    36
    29
    Jul 18, 2014
    Naperville il
    Parking brake switch make that problem, cruise/fast idle intermitent problems
  9. Bean Jr.
    5,468
    9,699
    Mar 30, 2014
    I think i may have discovered something. When I kick on the fast idle, the cruise won't work. When I don't it does seem to work. I'll try again to verify.
    If that's the case, what do y'all think of that?
  10. Bean Jr.
    5,468
    9,699
    Mar 30, 2014
    I appreciate everybody's help. I had to leave the truck running this last week because of the single digits and below zero. 2 things happened. First, the fan turned off, and second the cruise control started working all the time. I don't know what was wrong, but it's working now.
    BTW, it really is needed as it's a dual torque DDEC 2, so when I'm on the pedal, it's only 355 hp!
    Oxbow Thanks this.
  11. Bean Jr.
    5,468
    9,699
    Mar 30, 2014
    That was it. The dash valves had to be replaced. When I pushed in the tractor park, when on fast idle, it wouldn't turn off fast idle. Valve changed, cruise control works.
    Oxbow Thanks this.
