Cruise control on shifter knob
Discussion in 'Peterbilt Forum' started by Turbo3, Apr 13, 2015.
  1. Turbo3
    Turbo3 Bobtail Member
    4
    Can you get a cruise contol shifter knob for 13 speed eaton fuller trans
    I drove a truck several years ago that had it . I thought it was better than slced bread.....
    now an owner/operator and would like to install it on my '07 379 pete
  3. xsetra
    xsetra Road Train Member
    5,094
    6,940
    Aug 21, 2011
    Go to a dealership for your truck model. I'm sure they can get it for you. I have/had one in my Freightliner. When my trans was replaced the tech just cut the wires up the shaft. It was an easier install. I guess.
    May be try. Fleetpride. I would get an authentic eaton brand shift knob. Not the off brand.
  4. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    20,065
    Oct 23, 2008
    Wichita, KS
    Last one of those I had was on an original 379 extended hood with a mechanical 425 Cat. It was made by King Controls and was the gnats #####. You had a toggle switch to turn it off and on, a button to press to set it then a knob you could easily roll with your finger to fine tune the speed. Then at night, just roll the knob counter-clockwise and hit the button then roll the knob to adjust your idle speed.
    Yes it lacked resume and such but if you came upon someone and needed to back off you just roll the knob back a little then when you go to pass roll it wide open, make the pass then roll it back to where you were. Loved it and wish someone had something that would work in a similar fashion on newer motors.
    I have the steering wheel controls but HATE those stupid things, my hand rests right where the stereo volume is and I can't count the number of times while turning that I have turned the cruise on, set it, turned it off, adjusted the stereo, placed a phone call, blinked lights, changed trip meter settings, turned stuff off/on/up/down. Nothing gets a post trip going better than rolling down the highway with the tunes thumping then muting them as you exit to the truck stop then while backing in you accidentally un-mute the previously thumping stereo only to have AC/DC right in the middle of a full on scream.
    Redbeard93 Thanks this.
  5. Turbo3
    4
    Lol on ac/dc at full
    did that a few days ago..........almost had a cardiac moment😎
  6. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    If you remember the pete's I had, most had the CC/Jake on the shifter knob. Wasn't room on the dash for the switches.
    catalinaflyer Thanks this.
  7. catalinaflyer
    2,278
    20,065
    Oct 23, 2008
    Wichita, KS
    Yep, it's one of yours I was referring to. And 1505 (brown flat top FLD) had the King Control as well.
  8. wichris
    4,243
    8,447
    Jan 17, 2011
    You're not senile yet if you can still remember a truck# from 20 years ago. How about the PMS truck? Did it as a joke and they liked it.
  9. wichris
    4,243
    8,447
    Jan 17, 2011
    Turbo3, go to pete and they can order it. Going to need the wiring harness also. I might be able to get a vin# that has one.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    We added them to our 07 379's, the part # is 5586032 for the switch assembly, which is a Roadranger part # that you can get anywhere, Pete dealers are high. The harness you'll have to get from Pete though.
    You'll need:
    P92-6465 - Wiring Harness, Cruise Control Adapter
    P92-6646 - Wiring Harness Jumper, Shift Cruise Control Adapter
    Make sure that you leave a little slack at the switch and zip tie the wires good to the shiftier. The switches are fragile and if the wires are pulling on it, it breaks them.
