Crazy Loud Turbo Whistle!
Discussion in 'Peterbilt Forum' started by Jdsmoker, Mar 30, 2021.
  1. Jdsmoker
    Jdsmoker Bobtail Member
    6
    9
    Mar 30, 2021
    New to the forum.... My son bought a Pete with a C-15 6nz. Pulling a grain wagon. He has been complaining about a super loud whistle coming from the turbo. It starts around 15 psi boost and is obnoxiously loud thru about 20 to 25 psi boost. (I've driven the truck and can vouch for it) We've had it in a 2 reputable diesel shops and they have gone over it with a fine tooth comb looking for air leaks. We finally had the exhaust totally resealed to try and make sure. Still no luck. My son has read online about maybe sticking a silencer ring before the turbo??? I guess it is done on pickups sometimes??? We are out of ideas and getting a little frustrated. Any thoughts?
    Thanks!
  3. wore out
    wore out Numbered Classic
    15,347
    185,347
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Check the clean air side, usually middle of the y over the valve cover you will find a hole
    baha Thanks this.
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Sounds like a perfectly fine cat turbo to me. My 2ws is the same way.
    Bean Jr. Thanks this.
  5. Jdsmoker
    6
    9
    Mar 30, 2021
    I know their will be noise.... But this is CRAZY Loud! It is incredibly piercing. Loud enough that you would need ear plugs. If the noise was at a point in the boost that it wasn't their very long, a guy could handle it. But it is right in that 15 - 20 psi range and that is where it sits a lot going down the road.
    Trucker61016 Thanks this.
  6. Roberts450
    2,237
    3,635
    Feb 6, 2016
    Have you driven trucks with cats before?
  7. Capacity
    Capacity Road Train Member
    1,499
    3,116
    Jul 28, 2019
    Neenah Wi
    Bearings maybe , check for air leaks.
    Best way to tell is put it on the Dyno.
    Magoo1968 Thanks this.
  8. Jdsmoker
    6
    9
    Mar 30, 2021
    Yes I have.
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,701
    Mar 30, 2014
    That's what the 1693 sounded like. Crack the throttle, no engine noise, only turbo.
    That's what I'm talking bout!
  10. Diesel Dave
    8,531
    23,590
    Jan 20, 2010
    Hesperia, Ca.
    And the rattling marbles sound too.
  11. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    Complaining about cat turbo whistle? I’ll bet you can swap out that c15 for an emissions motor. That might be right up your alley bud
