This may be an unrealistic, yet noble goal/thought of mine. Perhaps you can help me.
What i want to be able to do is i want to, not nessesarily be able to "fix" a truck, but to be able to keep it running without ouside (i.e., dealer or shop) assistance.
An analogy might be related to cars; For example, 1965-through, say, 1987 GM cars and light trucks. i can keep these vehicles running without ever taking them to the dealer. This does not nessesarily mean i can "fix" them, but i can keep them running. For example, i don't have the capability or knowledge to rebuild a transmission, but i can quickly locate a replacement and swap it in all by myself.
So, possibly, a better way to put it is, i want to be able to know how to change parts on a truck to keep it running without having to take it to a dealer or shop.
NOTEs:
a) i am not, obviously, afraid to get my hands dirty or perform technical work.
b) i am willing to buy (more) tools.
c) No, i do not have a truck, but am considering getting one but i don't think it's a good idea to get one unless i can maintain it myself, hence all my questions.
d) While i am slightly mechanically inclined with or without cars, i am lost when it comes to diesel engines (although they are simpler than gas engines?) Also, trucks and diesels have components generally not found on cars---i.e., air compressors, the fuel filters are different etc.
1) Would getting the service manuals basically accomplish my goal(s)?
2) Are there any short courses or programs that you know of? Or would going to regular diesel mechanics school be a better idea? Note that i would rather keep the income stream going rather than to go to school at this point, but i am not completely ruling that out either.
3) The thought of "shadowing" an experienced mechanic around crossed my mind, but i am hesitant to approach a shop for fear of appearing "wierd."
Do you have any suggestions?
Crash Course In Diesel Mechanics?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Jan 8, 2008.
And as far as diesel engines being more simple than gassers, not at all - nowadays. An internal combustion engine in it's SIMPLEST FORM fuel by diesel IS more simple than an internal comustion engine fueled by gasoline (also in it's simplest form). Nowadays, they are both so complex I think they're neck and neck.
Take the old 6.9 diesels that Ford had in their F250 F350s back in the 80s. All you needed was a 1/2" wrench and a ball pien hammer to fix those things. 1994 saw the introduction of the PowerStroke Turbo Diesel. Forget trying to work on that thing unless you have lots of general engine knowledge, lots of diesel knowledge, lots of educational manuals and software, and a helluva learning ability. -
regular maintenance is a good thing leaving the other to the pros is the best advice that you can get will save you time and money
Most diesel repairs are cheap. Its the parts that have a significant cost is where the pain is.
110$ a hour labor gets expensive quick. Better learn to do somethings yourself. Every driver should have mechanical experience behind them.
I'm pretty sure most o/o are mechanically inclined. Can trouble shoot their problems and get them down to a point. Have their own tool box with necessary tools to do pretty much everything. Even a inframe if they have the parts. An air hose to reach all the way to the back of the trailer, with a impact wrench to break wheel nuts loose and a jack to lift the axle and yes of course a tire mounted on a rim already.
You won't see me on the shoulder for long. Only if I'm waiting for parts. -
I wanna remind yo one thing. Modern truck is combination of mechanics, air system and electronics. And I cant see any diesel mechanic who can solder small chips and use chip programmer, and I cant imagine electronic technician who does fifth wheel rebuild. So yes, you can do many things yoirself, swap parts from JYs, but not all.
later EPA 2010 and Euro-5 trucks with SCR are made for workshops!
and belive me, twony years later all trucks will be hybrid ore electric drive, so sweet time of trucks for DIYers is gone! -
Speak for yourself, if you are an electronics tech, then the future is yours!!
1. operate the equipment in a way that it will make it last forever instead of saving 10 cents every day
2. you will learn the weak points based on other people (using same stuff) problems and address them before they leave you stranded.
I got almost 800k miles on EGR-engine and was never late (doing produce/expedited all the time). I mean just do it, it works -
$110 per hour is expensive. Here's the thing... If you owned at truck, and it needed brakes, or a spring, or a clutch, or something like that, why would you go to a dealership and pay the high premium per hour dollars? We see a lot of customers come to use for basic stuff like that when there a other shops around that are more than capable of properly doing springs, brakes, and other stuff like that for way less. I think some customers simply make poor choices on where they take their truck. I certainly appreciate any work you want done. But if it were my truck, the $55 per hour spring shop will get my business for that stuff, and I will pay $110 per hour at the dealer for electrical and engine issues. Here is another tip, if you drive a Pete, don't go to a Volvo dealer to have it worked on, take it to Pete! Volvo dealers train their techs to know Volvos, not Petes or Freightliners, and so on. You get my point?
