Cracked windshield, OOS?
Discussion in 'Experienced Truckers' Advice' started by Dewey120, Feb 11, 2012.
  1. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    A good sized rock hit my passenger side windshield (at very top of windshield) a couple of days ago and left a thumb sized crater. Now a crack has formed in this area and is working its way down. The crack is growing about 2 inches a day.
    Is a cracked windshield an Out Of Service?
    Does it affect my CSA score if inspected?
    Thanks for your comments/help
  3. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    I was taught any crack that can't be covered by a quarter needs fixed. Not sure if it is an OOS but it would fall in the category of vision obstruction and would surely result in csa points in an inspection.
    Dewey120 Thanks this.
  4. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    Understand that I am just a regular driver not an expert.
    . If you have two distinct separate windshields - one windshield pane for the driver and a completely separate pane for the passenger - then cracks in the passenger side are no problem.
    .If you have a one piece windshield and the cracks appear on the driver side, it can be an OOS [out of service] especially if the crack is in your line of vision.
  5. Dewey120
    1,025
    456
    Mar 17, 2010
    Southern California
    I have a separate windshield for the drivers side and for the passenger side. I was hoping to get the passenger side fixed during my hometime in a week since I know a cheap place close to home.
  6. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    airforcetoo, goodchoice10 and Dewey120 Thank this.
  7. platinumcigarman
    platinumcigarman Bobtail Member
    11
    Feb 11, 2012
    MI
  8. Sly Fox
    Sly Fox Road Train Member
    1,016
    695
    Oct 29, 2009
    If it's a 'crater', you need a new windshield. A cat-eye can be repaired if you catch it usually the day or two after it happens.
    There's a lot of discrepency I've found from inspectors about what DQs you with a crack. One stated no cracks on the driver side window at all. One said only if it's where the wiper runs.
    But, I passed an annual and a roadside inspection with a cracked driver side windshield. Had a horizontal crack from about 5 inches from the left edge up about four inches, and then flat across to just before the center pane started creeping upward about an inch. It was right near where my 'hood' ends for my vision.
    The DOT officer pointed it out and I said I was well aware of it and if it crept upward at out of the 'hood' area of my vision I'd get it replaced. Got my little yellow sticker for a clean inspection. So, it really is up to the mood of the inspector.
    Mostly, because cracked windshields happen all the time. I'm changing my windshields about once or twice a year it seems from mostly rock chips or stress from the cold. So, I think the DOT on a roadside are a little more lenient than the letter of the rulebook.
  9. Dewey120
    1,025
    456
    Mar 17, 2010
    Southern California
    Had a level one inspection today at the scale house in California (I-80, west of Sacramento) and got my green 2012 sticker. I still haven't had windshield replaced but the guy inspecting my truck didn't even seem to care about. The crack goes from the top to the bottom now.
  10. StraightJakkit
    StraightJakkit Bobtail Member
    Louisville,ky
    i had an inspection about 6 months ago on a split window, i had a crack on the passenger side windsheild, the officer wrote it as a violation and explained that if it was on the driver side it would have been an out of service
