cracked pick up tube infuel tank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Jun 20, 2015.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    it appears my air in fuel is coming from pick up tube in tank. took fuel line loose from tank & found black piece of plastic tube in brass elbow. a baffle must be broken cause I can hear something clanging around in tank. the dealer said they show no part to replace pick up tube. they have access to aftermarket replacement parts, but looking at my tank, the fitting is welded where the elbow goes in.the pick up tube does not come out that I can see. some say to have end cut off re weld baffle & put new tube in, or get another tank.
    I do remember reading on hear years ago about intl having this problem with their tanks. cannot find a used tank locally & if I did it might have same problem, or soon develop it. any suggestions other than buying a new tank. 95 intl coe
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Thats pretty much your options, cut the end off to fix or get a new tank. You'll probably find an aftermarket tank for cheaper than a good welder though.
    TRP (Paccar) makes decent quality tanks for many makes. We've used them quite a bit since they are cheaper than OEM. http://www.trpparts.com/media/1005/trppffueltanks.pdf Measure it up and find a KW or Pete dealer. I've never got one for an international, but they're about $300 cheaper than Freightliner on most tanks. They make ones that fit our old FLD120's.
    heavyhaulerss Thanks this.
  4. RSQ20
    RSQ20 Medium Load Member
    You might find a pick-up tube that can be installed (as they use for Cab heaters)...
    .. Philip
  5. Strider
    Strider The Info Monster
    137
    1,996
    Aug 30, 2010
    Kansas City
    Does TRP also make the OEM tanks for the newer Paccar trucks?
    From this thread:
    http://www.thetruckersreport.com/truckingindustryforum/threads/cracked-fuel-tank-how.286953/
  6. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I'm not sure, but I would guess that they do, TRP is Paccar. How the heck did that happen anyway? If the tank is good otherwise, finding a welder to put that back together should be cheaper.
