Cracked axle housing.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kwforage, Jan 22, 2016.
  1. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Should I pull this out to weld it or do it in place? Weld it with our MIG or have the pros do it? Gusset it at all? Other axle has something similar on bottom side. I have the time and tools to easily pull the axle, want to do it right.
  3. OldSchoolCool
    OldSchoolCool Bobtail Member
    23
    16
    Dec 18, 2015
    Southwest Oklahoma
    My axle cracked at the same place and along the weld seams last year on my 402s. I removed the suspension and u bolts, so I could get in there and find the whole crack. I drained fluids and removed the vent and replaced it with a 1/4 QD compressor fitting. I pressured the housing to a few pounds of air and sprayed soapy water along every weld seam. I grinded a v in the all cracks. I use a mig and haven't had it crack back out yet. Since I had it tore down, I went ahead and rebushinged it while was there.
    joey8686 and josh polk Thank this.
  4. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    These are also 402's. I like the pressurizing idea, thanks.
  5. AModelCat
    154,238
    Kinda hard to tell if that's really a crack by looking at a picture. Good catch though! A lot of drivetrain component companies now offer their parts and service manuals online at their websites. You may get lucky and find a repair procedure. You could probably even call up the manufacturer and find out their recommended procedure that way.
    kwforage Thanks this.
  6. OldSchoolCool
    23
    16
    Dec 18, 2015
    Southwest Oklahoma
    No problem.. I was really surprised after I pressured and found more.. mostly at the weld seams behind the u bolts..
    Ruthless and kwforage Thank this.
  7. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I only found it because it was covered in gear oil before I steamed it off. I will check out Eatons site.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Have done several of them. If it is just a crack grind out and weld it. Set a air regulator at about 5 PSI ,hook hose up to vent hole, and spray with soapy water. Some times they are spider web'ed and must be plated. If it is on the front and the back I prefer to repair the original housing as much as possible. Then 1/4" plate over that and grind the axle seat to fit over the plates.
  9. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Are you guys hauling heavy for these to crack? Or is it just normal use and old age of the axles?
  10. josh polk
    josh polk Light Load Member
    142
    64
    Dec 20, 2015
    Bowie TX
    Just my opinion ID heat it with a rose bud before I welded it
  11. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    I use 7018 sticks but have hired a certified pipe welder on some that were really messed up.
    I have seen it on a road tractor, o/o with a tank company, due to neglect buy running loose U-bolts. It had worn the axle housing and brackets from slopping around. Probably had multiple failures before I saw it and it was spider webbed. Welded it up but it did not last, had to plate it.
    Also saw several from a scrap iron company. While at their office one day I saw them load and pack a high side trailer with a magnet then scale it. Then pack it, load and pack it some more, twice.
    Surely happens from age and fatigue sometimes.
    Usually starts from being ran loose. Hit the U-bolts with a hammer at PM services. Loose U-bolts move and or sound different. Tighten them, if they won't turn heat one flat on the nut orange and tighten it. If it still won't turn replace it.
