CPAP Tip for O/O
Discussion in 'Ask An Owner Operator' started by daddyhusky, Mar 21, 2021.
  1. daddyhusky
    daddyhusky Light Load Member
    80
    53
    Jan 23, 2009
    Atlanta, GA
    This might be old news for some, but DOT is now requiring a CPAP compliance report with physicals. A lot of carriers already did this but owner ops may not have (or want) someone monitoring their machine. You can print your own report from your machine by using OSCAR, an open-source software. It reads your SD card and makes a lovely report. (if your computer doesn’t have an SD slot, I got a reg/ mini SD to usb plug for $10 at Walmart). Here is the site for OSCAR: OSCAR - Open Source CPAP Analysis Reporter
    I hope this helps someone!
    tarmadilo, rachi, flybynight12 and 2 others Thank this.
  3. Wespipes
    Wespipes Road Train Member
    1,037
    1,815
    Jul 14, 2019
    I just go to a different doctor.
    Aamcotrans and TallJoe Thank this.
  4. TB John
    TB John Company Shill of BYOB & CBD
    3,348
    8,105
    Dec 28, 2008
    What does that mean?
  5. flybynight12
    flybynight12 Medium Load Member
    683
    539
    Jan 10, 2015
    slc
    It means sleep apnea is racist against truck drivers but some doctors help fight against racism
    Coffey and GreenPete359 Thank this.
  6. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
    The doc you go to for your physical may require a report but the FMCSA does not.
    As far as OSCAR, it is a good tool for CPAP users to monitor the machine usage and effectiveness. You can, as you say, print out a report. Most machines also have a built in modem. If I want a report I can call the local office and they will run a report, and either I can pick it up or they will email it to me.
  7. TB John
    3,348
    8,105
    Dec 28, 2008
    1st truck drivers aren't a "race" to be "racist against. 2nd, you'd switch doctors to find one that would tell you what you want to hear? Why bother going to the doctor just tell your self you're fine, cut out the middle man.
    Aamcotrans Thanks this.
  8. daddyhusky
    80
    53
    Jan 23, 2009
    Atlanta, GA
    I stand corrected. It must be a new requirement for CVS DOT Physicals. In my case, I didn't have a local office. It was being monitored by a 3rd party for my previous employer, so it was much easier to just print the report rather than trying to sign up with a monitoring company or the manufacturer. When I replace my machine, I will probably make sure I am set up with remote monitoring with the manufacturer or their monitoring company. For the time being, however, OSCAR is my friend. Thanks for the reply!
    kemosabi49 Thanks this.
  9. flybynight12
    683
    539
    Jan 10, 2015
    slc
    Since you deny it you are part of the problem shame on you no driver will want to be part of a racist trifecta lease
    Coffey Thanks this.
  10. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    I can't believe you bit on that. ####, driver.
    Coffey and flybynight12 Thank this.
  11. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    You might want to put the bong away before posting.....
