Cost to repair dry van trailer side panels
Discussion in 'Ask An Owner Operator' started by audax81, Apr 25, 2020.
  1. audax81
    audax81 Bobtail Member
    7
    7
    Jun 29, 2013
    I'm considering buying a 2015 Great Dane dry van but it did tip over on its side, so one side has some damage. It appears to be cosmetic, but if I do need to replace the side panels, what's a ballpark figure for how much it costs to replace a panel?
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i hope you have that trailer fully inspected, measured, to make sure it is square, otherwise, you'd be buying scrap metal.
    bzinger, Dino soar, 86scotty and 5 others Thank this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Yeppers, Alignment would be a much bigger concern than a hole or two on the side.
    As for your question, depends on how much you want to spend. As low as $20, up to several thousand. Slapping that rubber foil tape stuff will make it sound, if ugly.
    Cutting out just the hole and riveting a patch is much cheaper than a full panel, looks better than foil patch, but is still obviously a fix.
    Then there is cutting out the whole panel and redoing it, which isn't cheap and usually overkill.
    Dino soar and audax81 Thank this.
  5. Vijay2020
    Vijay2020 Bobtail Member
    How much does it cost to replace full panel on 53 ft dry van
  6. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    My own opinion is that it's just better to buy something that's in good shape.
    Even if you get something like I did, something older that needs mechanical repairs that are straightforward, but overall is good and solid.
    I looked into replacing those panels before, and I don't remember the cost but it takes two guys to do it so I would imagine it's pretty labor-intensive in addition to the panels and the rivets.
    You really would have to call the dealer and ask what they would charge for that.
    But I would stay away from something that's been flipped over.
  7. Vijay2020
    The scratches repair cost and what’s that part name on dry van 52 ft
  8. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    That's not the panel, that's part of the frame and not cheap. If it's an insurance clam because you were hit take it to a trailer shop and get an estimate. If it's a trailer you are buying, just ignore it, or take a Dremel and polish it up so it doesn't look bad if it bothers you. It's not a structural problem, just a visual one.
    Dino soar, Vijay2020 and gentleroger Thank this.
  9. GraniteRiver
    GraniteRiver Light Load Member
    208
    285
    Apr 22, 2018
    Its about $1500 per panel
  10. Rideandrepair
    17,204
    55,809
    Aug 8, 2015
    That’s pretty common damage. Not worth worrying about.
