Correct gov cut-in psi.
Discussion in 'Trucking Schools and CDL Training Forum' started by DMphantom, Mar 26, 2017.
  1. DMphantom
    DMphantom Bobtail Member
    Aug 24, 2016
    hello, I'm getting ready to go take my skills test for DMV and I'm trying to find out the correct gov cut in psi for the airbrake test. My air brake inspection sheet I got from my driving school says 100psi. Then I have another air brake inspection sheet that says the governor cuts in at 85psi. so what one is actually the correct psi. DMV book says 100psi then the DMV instructor says it's wrong.
  3. austinmike
    86,019
    I think it's 100.
    fargonaz Thanks this.
  4. JReding
    JReding Road Train Member
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    Have you respectfully asked the instructor for clarification, and shown him/her the guide?
  5. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Go by what the book says ,that's the number the DMV will use.
  6. UsualSuspect
    UsualSuspect Road Train Member
    1,257
    1,979
    Aug 14, 2016
    Yo Mama's
    It should be in the Commercial Handbook DMV prints out, makes a pdf of, etc.
  7. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    This is for 'motorcoaches' I couldn't find anything for trucks.
    Air compressors typically have a "cut-out" pressure between 110 psi and 130 psi and a "cut-in" pressure about 20 psi lower. Air pressure build-up from 85 psi to 100 psi should take 45 seconds or less
  8. DMphantom
    Aug 24, 2016
    Yes, I've asked the driving school instructor and I was told cut in was supposed to 85psi.
    I'm going to stick with what the DMV handbook says. Thank you all for your replies.
    JReding and fargonaz Thank this.
  9. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    Cut-in: 85psi minimum
    Cut-out: 130psi max
    Blow-off: 150psi
    Low air warning: 55-75psi
    Auto application: 20-45psi
    Leak down static(1min);
    Single: 2psi
    Combo: 3psi
    Doubles/triples: 5psi
    Leak down applied;
    4
    6
    Build-up:
    85 to 100 in less than 45 seconds.
    TA
    WildTiger1990 and EZ Money Thank this.
  10. Twin Screws
    Twin Screws Light Load Member
    200
    130
    Apr 5, 2014
    The correct cut in PSI is 100. It is stated clearly several times in the CDL manual. Cut out is 125 PSI.
    The only time 85 PSI is mentioned is when you check the compressors refresh rate, which should be from 85 to 100 PSI within 45 seconds for a dual air system. This has nothing to do with governor cut in and cut out pressure.
    150 PSI - Safety Valve
    125 PSI - Governor cut out
    100 PSI - Governor cut in
    60 PSI or above- Low pressure warning
    20-45 - Emergency (spring) brake activation.
    The examiner is an idiot....they usually are.
    speedyk and fargonaz Thank this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I expect low air warning when both or either P and S reach 60 and fall through.
    I expect the compressor to wake up and get to work feeding tanks at 85 or higher. 100 is outstanding. I love to keep as much as I can get into those tanks. Never know when you can use them. I have had several real world problems of air loss and failure of braking systems in my time out there. Everyone of those events demanded me to write my own book on how to get out of the situation safely before the spring brakes clamp everything down.
    Tests are difficult. Learn the book for your location and parrot it. When you get assigned a truck and be on your own you will discover that all trucks have a certain amount of... personality in regards to air and everything else.
