Correct ATF fluid?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sarrattseptic, Jun 29, 2024.
  1. sarrattseptic
    sarrattseptic Bobtail Member
    48
    25
    Aug 21, 2020
    Waynesville, North Carolina
    This is for a 1989 Ford L9000.
    For the power steering the Ford service manual says Mercon multi purpose atf xt-2-qdx or ddx e4az-19582-b OR equivalent.
    This is no longer made.
    I called the Ford dealership and they said Dexron V.
    And....I just want to make sure. I don't want to put something in the system that will make me rebuild something.
    Can anyone confirm that Dexron V is okay? Does anyone have any experience with exactly what I should use?
  3. Rideandrepair
    17,205
    55,810
    Aug 8, 2015
    The latest Mercon available is my guess. Dexron was originally developed by GM in the early 50’s. Ford and Chrysler both bought it from them. Later Ford developed their own brand, Mercon. I’m sure either one will work. It’s only PS not a transmission. Lucas makes a PS fluid, and there’s plenty of universal PS fluids available. They all will probably work. They’re all hydraulic fluid. Good thin ATF will work best, any brand, especially in colder temperatures. More prone to minor leakage though if seals are old. If you can see any trace of what was used, might help. Though someone may have used something different than original. Typically Dexron is red, Mercon is blue. Since it’s a Ford, I’d go with Mercon. Usually the newer blends supersede the older ones. My old cars require Dexron 2, Dexron 5 or any Dexron made between 2 and 5 works. I prefer the older stuff if I can find it, because it’s a lot cheaper. So, cheapest Mercon (type) available, any brand, should be good.
    Goodysnap and sarrattseptic Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    PS is very forgiving and tolerant to different types of fluids. Back then, I remember seeing good ol' Dexron 3 in lots of Fords. Internationals came filled with regular 15W40 right from the factory. Both had same gears and pumps. Today it is usually just a good quality name brand of power steering fluid. I would try to stick with whatever is currently already in the system. If it is dry, then it really honestly doesn't matter.
    Goodysnap and Rideandrepair Thank this.
  5. ElmerFudpucker
    3,744
    39,200
    May 17, 2024
    It really doesn’t matter what atf you stick in it. All of it will work. So buy a cheap quart and roll on
  6. sarrattseptic
    48
    25
    Aug 21, 2020
    Thanks to you all!
    Heavyd and ElmerFudpucker Thank this.
