Coolant temp. sensor replacement help?
Discussion in 'Kenworth Forum' started by Patriotleasing, Aug 28, 2021.
  1. Patriotleasing
    Patriotleasing Bobtail Member
    28
    Jan 1, 2017
    Anybody in here know if there is a separate sensor for HIGH coolant temp from the regular coolant temp sensor? High temp warning comes on sporadically sometimes at 190°, sometimes at 205°. Hell, it came on the day just idling at a customer at 180°. Already changed the sensor on the front of the thermostat housing but didn't solve it. Maybe changed the wrong sensor? Any help would be appreciated.
  3. Patriotleasing
    28
    Jan 1, 2017
    Sorry, talking about a CAT c15 Acert.
  4. 062
    062 Road Train Member
    6,143
    33,182
    Oct 20, 2013
    Probably have two sensors. One for the gauge another for ecm.
    @spsauerland
    w9l, Patriotleasing and spsauerland Thank this.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Truck model, year, last six of VIN if Paccar.
    062 Thanks this.
  6. Patriotleasing
    28
    Jan 1, 2017
    '05 KW T600. Last 6 - 087361
  7. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    P/N for switch for high temperature switch is Q27-6000-225. It is in port 34 in this screenshot.
    Port 12 is sending unit for gauge. Which did you replace?
    Patriotleasing, QUALITYTRUCK and 062 Thank this.
  8. Patriotleasing
    28
    Jan 1, 2017
    Yup, replaced the sensor in port 12. P/N 16-10407. Figures. Will order the correct one Monday. Thank you for your time and help!
  9. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Don't feel bad. You changed the easier one to access. Make sure you come back and update everyone on how "easy" it was to change the sensor!
    spsauerland Thanks this.
  10. Patriotleasing
    28
    Jan 1, 2017
    Really wasn't bad. Mechanic had it done in 15 minutes. Drained about 5 gallons of coolant, grabbed a deep well socket and boom! Done.
  11. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    Had an 05 379 with Acert that I never could keep the temp gauge from running amuck. Replaced both sending units- one for gauge and one for ecm. Replaced gauge with new. Worked ok for a few days then back to showing hot all the time vs checking with temp gun or ecm. Finally bought a Scangauge D to monitor what ecm was reading and problem circumvented. Scangauge D is a pretty handy item.
