Coolant refillers
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gperez90, Feb 5, 2020.
  1. Gperez90
    Gperez90 Bobtail Member
    Looking into buying a coolant system refiller any suggestions ? Snap-on , Matco, Uview, robinair?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    what is coolant system refiller ?
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Any of them that have a tank that the freon gets pumped out of system into will work .
    Gperez90 Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    This is the best bang for the buck as far as I am concerned. All brass, durable and the venturi is strong.
    If you have deep pockets the Snappy and Matco ones work great too.
    Gperez90, SAR, baha and 2 others Thank this.
  6. Gperez90
    It is a device that pulls a vacuum in the cooling system. It gets rid of air pockets so you don’t damage def components or coolers. It works with compressed air
  7. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    ok. cooling system tester for hd trucks.
  8. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    The use started in autos with extremely hard to burp systems that would hold and trap air pockets during refill process. Overheating, loss of heat , so on.....
    They really are a life saver if you have a vehicle prone to air pockets and vacuum filling Is the only way to ensure there is no trapped air.
    spsauerland and Gperez90 Thank this.
  9. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I had many cars and only 2000 and up BMWs had problems related to air pockets during coolant change. HD truck engines don't have that problem, I never seen them. I have my own made cooling system pressure tester for Detroit/Freightliners .
  10. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    I’ve got the snap-on version. I had to get the adapter for the thread on pressure cap for the plastic tanks on the Freightliner’s, which made it easier to get a good seal. We got tired of pulling a vacuum, wait to fill, pull a vacuum, etc. So we pull the de-airition hose off of the surge tank, plug one end, and put a hose from the other down to the bucket. Then leave the air on till the surge tank starts filling or the buckets are empty.
    One of the Best time and effort saving tool I’ve made the company purchase!! As long as your not stuck on the line by line instructions sent in the package!!!
    spsauerland and Goodysnap Thank this.
  11. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    drill 1/8 inch hole in thermostate problem solved works for about any engine gas or diesel
