coolant loss out of overflow hose!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by riflemen, Mar 24, 2010.
  1. riflemen
    riflemen Bobtail Member
    19
    Feb 28, 2010
    Manitoba
    Well, I had just bought a used 379 with a Cat bridge engine with 240 000 miles on a new head/gasket/o rings/liners-UTP had just ran out in Nov 09. Noticed that when I got her home it had coolant leaking from rad overflow hose. Stuck hose in some water and bubbles are blowing out. Did notice cap was 7lb and was told it should be a 16lb cap. How do you test if it is a compressor leak? Not looking good anyways:biggrin_25513:
  3. Slim Pickens
    Slim Pickens Bobtail Member
    22
    17
    Oct 17, 2008
    Illinois
    I had the same problem on a 3406E. 7# cap also.....changed to a 10#.....end of problem
  4. YETI1
    YETI1 Light Load Member
    182
    40
    Jan 1, 2008
    kansas
    are you sure it doesnt smell like diesel?:biggrin_2556:
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    i had same problem end up being a cracked liner. or it could be a compresser isolate the water supply to compresser but run water through it with a gardenhose and see if that stops the bubbles. if not find out if they checked liner protrution when they had the head off. cat has very low specs for this i learned the hardway.
  6. Slim Pickens
    22
    17
    Oct 17, 2008
    Illinois
    No diesel in coolant.....cap solved problem for me.....been ok for over a year now
  7. WallyGator
    WallyGator Medium Load Member
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    had same problem with my 3406e it had air in the cooling system. theres a petcock valve on the upper rad hose. run motor cold not hot and bleed off air.sounds crazy but it worked.o i forgot to tell you open heater valves or youll keep getting air. Walt
  8. riflemen
    19
    Feb 28, 2010
    Manitoba
    I don't seem to see any petcock valve on my upper rad assy. The fun just keeps getting better, also notice that Horton fan clutch is on its way out as well.
  9. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    it was worth a try.have you done a leak down test yet?
  10. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Try the cap replacement first off. It is the cheapest and most likely. Of course another possibility is that the cooling system is overfilled, so it boils out when it gets warmed up....
  11. tsass
    tsass Bobtail Member
    Try a new cap first. I had the same problem on a 3406e. Cracked liner was the culprit.
