Coolant level low warning light,
Discussion in 'Ask An Owner Operator' started by feldsforever, Aug 8, 2020.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Here's what i know,
    At very random times the light/message/ code, will come across the dash. The temp gage is still showing good temp. And to the best of my knowledge is working like it should
    The coolant level is fine. The boss replaced the actual sensor in what I'm guessing is the resavor tank. And refilled it to the right level. The code is still there.
    I unplugged the sensor. And zip tied it out of the way.
    I'm sitting on a 48 hour restart. I plan on plugging in the sensor and attempting to clear the code. Via power off for 15 mins. Cycle the key three times, then start it on the fourth cycle.
    If this does not work. What is the next step?
    2016 cascadia, automatic.
    Thanks in advance.
    truckdriver31 Thanks this.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Don't worry about temp gauge to low coolant.
    The alarms are set for 2 quarts low. Give or take.
    Trucks hold 13ish gallons. Give or take.
    If the problem is fixed. I beleive the code will eventually disappear. I could be wrong though.
    Codes stay if the problem stays active. No need for code if it's no longer active.
    Trucks usually shut down too when the alarms come on. My 07 dings, lights on, and shuts down when it's 2 quarts low.
  4. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    those units need filled above line. when doing a park regen. the water pump sucks it pass the low coolant sensor. keep it about 1 inch above line and you wont have anymore problems.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Can also be a bad wire.
    You can drive fine with the sensor disconnected, just the check engine light will shine.
    Once fixed the light will go out on its own within three driving cycles or sooner.
  6. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Trying the reset. Did not work.
    The fluid is full to the full cold line.
    After I eat. I will see how far back I can trace the wires to see if they are broke.
    Still getting the red stop engine light
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    I pulled the wires from the plastic houseing as far back as I could. I didn't see a break. So in the next week or two looks like he's putting it in the shop.
  8. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Ok different question. When I check the oil. I Usally let it sit with the engine off for 25 mins or so. Or first thing in the mornings. Does the spy also Have to Not be ran.?
  9. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    fill above line. when is this happening
  10. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Do you still get the stop light even with the plug disconnected from the sensor?
  11. feldsforever
    1,453
    1,440
    Nov 22, 2019
    No
