Coolant leak from reservoir tank cap
Discussion in 'Freightliner Forum' started by irishluck09, May 3, 2021.
  1. irishluck09
    irishluck09 Light Load Member
    268
    133
    Nov 24, 2019
    2014 cascadia dd13
    Ive noticed i have coolant coming out of my top coolant cap on my reservoir tank
    Just wondering if ya'll think my cap is bad or if i have a underlying issue causing too much pressure?
  3. Antinomian
    Antinomian Road Train Member
    2,076
    3,241
    Feb 17, 2013
    I'd try a new cap first. If the pressure goes over 15 pounds it should vent through the side cap, not the top.
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    The rubber 0/ring on cap is cracked or broken, put a new factory cap not a china made copy on it.
    AModelCat Thanks this.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    loosen it some where it dont build pressure. see if it still comes out.
  6. Ridgeline
    22,103
    113,210
    Just start with replacing the cap, the actually where out.
  7. irishluck09
    268
    133
    Nov 24, 2019
    Yea i figured just a bad cap. I mean i can physically see it bubbling out from the bottom of cap. And the truck isnt overheating or anything
    truckdriver31 Thanks this.
  8. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    my second truck never did. i bought a pretty purple freightliner from select trucks once. paid cash. truck never made it past 6 months. come to find out cap had just 1 o ring on it to keep pressure from building. i put new cap on it. truck used 2 gallons a day of coolant.
  9. Joyce's Volvo
    Joyce's Volvo Light Load Member
    96
    132
    Jun 28, 2016
    Don't want to be the bearer of bad news but, you could have other issues. Take cap off (carefull if it's hot )and start up , look in with light and see if it's got bubbles , if you got Constant bubbling it could be bad to worse, bad= air compressor , worse= head gasket, devastating = cracked head. Don't forget about ,expansion if you filled too much, as it warms the water will expand in volume % wise to temp, hopefully your just over filled.
  10. Antinomian
    2,076
    3,241
    Feb 17, 2013
    But in that case it should still be venting out of the side cap, not out of the top cap.
