Coolant coming out of exhaust pipe.Series 60.
Discussion in 'Freightliner Forum' started by Damage, Sep 28, 2012.
  1. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    We have a Series 60 in a 2002 freightliner that just turned over a million miles(Its a non egr engine). Today it shut down for low coolant. Tried adding coolant, found coolant running out at flex pipe as fast as we filled it. Sounds like a head or head gasket? Any input? Thanks.
  3. Driveone
    Driveone Light Load Member
    53
    10
    Oct 26, 2011
    South Carolina
    Probably there is little cups the injectors sit on and if the o rings wear out which they do with those kind of miles they tend to let water seep through my guess
  4. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    When you take off the cap to your coolant reservoir can you smell fuel or is it slippery to the touch. I had a similar problem and my injector cup seals were cracked. Thought it was head gasket but fixing seals on injector cups was a little cheaper.
  5. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Injector cups might be. Have to remove head on 12.7 and have them installed. You need to remove head anyway with that amount of water flow and have it checked. You might need a head.
    With that many miles you might need to weigh the plus/minuses of inframe at this time.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I sugest bad head gasket ore bad injector sleeves.
