coolant color
Discussion in 'Experienced Truckers' Advice' started by againstthewind, Jan 7, 2017.
  1. againstthewind
    againstthewind Road Train Member
    2,027
    3,164
    Oct 26, 2012
    ive used the green, used the red, truck i have now takes purple, now i see there is pink, or is that purple? i remember having a debate with my woman about how somthin that was pink she said was purple so maybe im color blind. lol and i know its probably already been said but which ones can u mix with which.
  3. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Lol, the one that you and your lady argue over is the Fuchsia color. Its in between a pink and purple color. In my personal vehicles, Toyotas, use pink coolant
    againstthewind and KillingTime Thank this.
  4. KillingTime
    KillingTime Road Train Member
    3,865
    61,880
    Mar 26, 2016
    Rockland, Maine
    So is the green really green? Or is that chartreuse? Lol.
    bigkev1115 Thanks this.
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    From Newsome Oil Company...
  6. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    I have been taught do not mix any of them. Green is regular
    antifreeze and the colored ones are extended life. Different
    manufacturers use different colors. Try to find out what the
    truck has in it before you add any. Sometimes they have a small
    tag showing what was installed from the factory......Good luck.
    againstthewind Thanks this.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Just don't mix regular green with any red or purple extended life or vice versa. However I'm given to understand it's okay to mix different [red or purple] extended life fluids if you need to.
  8. againstthewind
    2,027
    3,164
    Oct 26, 2012
    haha ya i remember her using that word in our debate now that u mention it. lol
  9. againstthewind
    2,027
    3,164
    Oct 26, 2012
    take that up with my woman, she knows her colors lol
    KillingTime Thanks this.
  10. Toomanybikes
    Toomanybikes Road Train Member
    2,360
    3,120
    Apr 8, 2009
    Green and red (more of an orange) is practically the same stuff.
    The difference is green uses silicates as corrosion inhibitors. CAT blamed these silicates as the cause of their water pump failures some 20 years ago. I tend to think it was their cheep imported parts at the time but truth is IDK and no one else has good conclusive answers.
    You can blend both types because they are basically the same ethylene glycol for about 98-99% of the composition. Only a small % of the corrosion inhibitors differ. Manufactures say that only after you get past 10-20% dilution of the orange with the green, does the long life corrosion protection of the orange suffer.
  11. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I might have said red when I should have said orange. I guess bottom line is there is the "cheap" antifreeze and there is the really expensive extended life antifreeze and ideally these should not be mixed
