Convert UHaul 14' Box Dually to Reefer
Discussion in 'Experienced Truckers' Advice' started by chefjeffsgrill, May 21, 2012.
  1. chefjeffsgrill
    chefjeffsgrill Bobtail Member
    Bakersfield, CA
    I have a small catering business where we pull around our mobile catering trailer and I need more storage for food and supplies to go to larger events. It can get a used Uhaul 14 foot cab over box dually for $3,500 that has a towing capacity fo 7klb. How do I convert it to a mobile cold storage at 35 degrees. I'm in souther California, often 105-110 degree summer days. Obviously paint the roof white, what kind of small top-mount reefer. What kind of flooring insulation, wall & roof insulation, roll up door insulation? etc. Food grade for safety, but no inspection or certs needed. How would you do it, details please.
  3. chefjeffsgrill
    Bakersfield, CA
  4. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    Lonesome Thanks this.
  5. Crusty
    Crusty <b>Just Plain Crusty</b>
    345
    140
    May 29, 2010
    Canton, GA
    I taught McGiver everything he knows. But I would opt for a used box/reefer unit instead of conversion. My main concern with your proposal is gross weight. Do some serious research. My guess is that you will be overweight for a U Haul chasis. ALL chasis flex to some degree. This is not something to toy with. Make sure b4 you do it.
  6. starsonwindow
    starsonwindow Medium Load Member
    569
    165
    Feb 2, 2012
    Phoenix, Arizona
    I would not go with a U-Haul dolly to move the food to the trailer!!!:biggrin_25513: Like stated they are the worst in repair, U-haul only works the workers at all of the locations on a part time basis, they get no benefits or anything, The trucks are hammered mechanically wise, They are not taken well care of, Ever heard "Drive it like a Rental"? That is where this phrase came from! I would not do this, Setting it up would cost you way to much money only to be relying on a not reliable chassis!!:biggrin_25513::biggrin_25513:
    Leftlane101 Thanks this.
  7. SuperLiner
    SuperLiner Light Load Member
    287
    163
    Dec 26, 2010
    Good Ol' Arizona
    There may be some insulation issues as well for a box that was not intended to be cold storage, the thing may not be insulated enough to pull the temps you need with a refer unit sized to the box. as well as sealing issues.
  8. Lonesome
    Lonesome Mr. Sarcasm
    10,941
    22,201
    Dec 15, 2007
    Northern Indiana
    Personally, I would look for a used refrigerated truck, VS trying to do what you're proposing. You will need a lot of insulation, a refrigeration unit, a way to run the refrigeration unit, some sort of covering for the insulation, etc.....
  9. Crash935
    Crash935 Medium Load Member
    329
    163
    Sep 8, 2007
    Wyoming Mi
    times 2...
  10. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah, a regular insulated reefer truck has way more than you could do to a U-haul truck. You might try and look into a freezer type thingy like an ice cream truck uses with dry ice. Different sizes are available.
  11. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Not worth the trouble, buy an insulated box with small refrigeration unit on it.
