Container securement to S/D
Discussion in 'Ask An Owner Operator' started by 66truck, Oct 10, 2010.
  1. 66truck
    66truck Light Load Member
    136
    29
    Nov 7, 2008
    ohio
    I need some ideas on the best way to secure an empty container to a step deck not using container locks.
    Thanks for all info
  3. RenegadeTrucker
    RenegadeTrucker Road Train Member
    2,754
    2,383
    Dec 25, 2009
    Montana
    Might I sugjest 4 chains, 4 ratchet binders and 2 4" straps?
  4. 66truck
    136
    29
    Nov 7, 2008
    ohio
    I was thinkin that , seems like I have seen guys with just 4" straps on them before, just never looked that close.
    Thanks
  5. Katz
    Katz Medium Load Member
    525
    234
    Jun 21, 2009
    Commiephonya
    The pic shown is securement on a flatbed, but you can do the same if you have 40'+ bottom.
    Up front, you may have to use a ratchet on each side instead of one in the middle due to lack of room.
    I always use some straps in addition just to keep DOT off my back even if the can is empty.
  6. RenegadeTrucker
    2,754
    2,383
    Dec 25, 2009
    Montana
    If you have a 37 or 38 foot lower deck with a 40' container, you can not legally pull it in California. (or 2 20's)
    My prefered meathod for securing the can is to run a chain at the front through the holes in the bottom corners of the can, then hook that chain to its self, run the chain down through the spool behind it, then pop it up over the next spool, then down again and hook the stake pocket a few down and put your ratchet binder between.
    Then on the back of the can I will run my chains from the upper corner's of the can to the rear most spool on the trailer, then do the weave and chain again. I tie off the excess chain with a couple of heavy zip ties.
    Then I will toss a strap over the rear and over the front about 10' from the ends of the can and sinch em down good, I also twist the strap so it doesnt flap in the wind and beat against the can.
  7. 66truck
    136
    29
    Nov 7, 2008
    ohio
    Thanks guys, thats the info I was looking for , California will never see my truck, no desire to deal with their BS.
  8. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    I thought Ca. allowed EMPTY cans to overhang on a step-deck, but not loaded. But I could be wrong or things could have changed.
  9. RenegadeTrucker
    2,754
    2,383
    Dec 25, 2009
    Montana
    they will allow empties, or would the last time I was out that way, but really overhanging one is a good way to get some unwanted attention.
  10. 66truck
    136
    29
    Nov 7, 2008
    ohio
    It shouldnt matter as long as its empty as FMSCA rules say it can hang over 5' front or rear as long as its secured properly.
  11. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    Only when empty.
    Looks like California is just enforcing the Federal rule to me.
    RW. Thanks this.
