considering pulling a reefer, need advice.
Discussion in 'Refrigerated Trucking Forum' started by lane379, Mar 27, 2016.
  1. lane379
    lane379 Bobtail Member
    13
    7
    Mar 26, 2016
    I'm considering getting into hauling refrigerated products, but I've never been around that part of the industry. Have only been in the agricultural part of trucking. Lookin for advice as far as type of trailer (prefer spread axle), type of unit, what to look for on the trailer, basic procedure setting trailer temp an cycles, best way to check temp during transit, what to look for on products while loading, like to know about temp recorders, how much money can be made pulling a reefer, reefer operating costs, shippers that are good to pull for, good brokers (prefer pulling directly for shippers, but doubtfully starting out), any good fuel cards, what type of products to haul.
    Dominick253 Thanks this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Nice first post. .. will there be anything else? Shall I just send you money instead of you having to go through all that work?
  4. lane379
    13
    7
    Mar 26, 2016
    Just lookin for some advice. Don't have to answer every question I was hoping people would answer what they want an eventually cover all of them.
    Dominick253 and Puppage Thank this.
  5. 201
    201 Road Train Member
    12,047
    24,590
    Apr 16, 2014
    high plains colorado
    Hi lane, welcome aboard. I pulled a reefer and quite honestly, it was the least favorite aspect of all my years in trucking. Reefer loads are inherently heavy, as the trailer weighs so much. Spread axle trailers are nice, but you don't see a lot of those, so axle weights are all over the place. Generally, not always, the places you go are just the worst places. Loading, unloading, crabby workers, LOTS of "finger printing" ( take a layer off, put a layer on, or heaven forbid, all goes on small wood, do they still have small wood?) Speaking of wood, many times, your pallets aren't good enough, and have to buy theirs ( which in many cases aren't any better) Then there's the trailer, although, reefers have come a long way, they still are a pain ( fuel, repairs) Reefer seems to pay a little more, but for me, wasn't worth the hassle. I think the neatest gadget for reefers, is the backwards LED temp reading. A quick glance in the mirror, gives you the temp. ( years ago, you had to stop and look) I'd never pull a reefer again, as I heard it's gotten even worse at these cold storage places. And don't get me started on grocery warehouses. Personally, a tanker or dump truck is the way to go. Good luck.
    darthanubis, JB3, RookieJ1987 and 5 others Thank this.
  6. rocknroll81
    rocknroll81 Road Train Member
    1,332
    930
    Sep 29, 2010
    West Allis Wi.
    I think you should start surfing the Refrigerated forum, you should get a lot of info. As far as trailers go, if buying new it seems as for weight Utility with a Carrier unit are the lightest, you could check the weight of Great Dane Everest TL. Checking temps while driving is pretty much a thing of the past as they no longer have a mounted light indicator showing reefer function, to check temp you will have to stop and get out and look. As far as Temp Recorders go, some shippers might put one in the load and not tell you, some will let you know about it and note it on the B/L along with the recorder number.
    darthanubis and Dominick253 Thank this.
  7. tonycr
    tonycr Light Load Member
    109
    20
    Feb 28, 2013
    just read read read all your questions have been asked and answered on this form
    darthanubis Thanks this.
  8. lane379
    13
    7
    Mar 26, 2016
    Yea I've pulled a tank around quite a bit, actually looking at a a tanker deal too. It's just I know that part of trucking. I got some local guys maybe lined up that eun regional do you know any OTR tank companys?
  9. lane379
    13
    7
    Mar 26, 2016
    Yea I've been reading alot on here an have learned a lot I just had some specifics maybe I get answers sooner than I found all of them. Just gave it a shot lol. I read if they don't tell you or not it an make you sign about the tr then shipper can't prove it was there. Was told you have to know about it.
    rocknroll81 Thanks this.
  10. 201
    12,047
    24,590
    Apr 16, 2014
    A member named "Chinatown" is our "go to" guy for that. It's probably like 3am there, but he'll get back to you. I've been out of the loop too long, but some people do ok with reefer, but it's usually because they've had the account for a long time, and new guys get all the crap nobody else wants to haul. If I pulled a box again, it would be van work. Seems that's the lesser of 2 evils.
  11. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    I wouldn't recommend a spread. There are many loads that require the ability to put 30 pallets on a trailer. You can't get that on a spread.
    Experience varies but I haven't had much issue with wait times or Lumpers. The grocery warehouses have the worst rep. But 3-4 hours is pretty standard.
    Someone mentioned buying pallets but I have yet to encounter that. Maybe if you were doing LTL and getting freight from small operations that might come into play. I would say 99.9% of reefer freight is already on pallets and you won't have to deal with it at all.
    Many reefer loads are heavy. These customers will cram as much on there as they can. I don't see this as a problem. These trucks are designed to haul up to 80k pounds; a load is a load.
    It sounds like you are wanting to lease on with someone. Try and get a percentage deal. Most guys paying mileage are only paying .97 - 1.00 per mile + FSC which is low right now.
    Reefer is all about time management. If you go into it knowing the live loads and unloads can take a few hours you can plan for it and manage the clock accordingly.
    The reefers themselves are pretty solid. Just check the oil once in awhile, coolant, belts, and flip through the gauges in the ECM on it. Not much to it.
    hunted and Dominick253 Thank this.
