Connex CB Radio
Discussion in 'CB Radio Forum' started by Treefork, Feb 21, 2013.
  1. Treefork
    Treefork Road Train Member
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    Is that Connex 566sb a decent cb?
    Been thinking about getting a new radio and like the looks of it and that it's CB and not 10 meter radio.
  3. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
  4. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    I don't think these reviews are worth a whole lot unless you test several radios. There can be quite a bit of variance between identical radios. (That is why you need to have any radio checked by a competent technician even new out of the box!) I doubt if there is any performance difference between this radio and the Galaxy equivalent. Probably have the same parts in them. The review was well done however.
  5. Treefork
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    Ok thanks for the replies. Might look into one sometime this spring. Just looking for something flashy but functional. Right now I switch between a Cobra 29 LCD (2011) and a Cobra 148GTL (1993). The 29 has been peaked/tuned, the 148 I've never done anything to, but my dad gave it to me in 2008, not sure if its ever been messed with or not.
    Speaking of, ran into my dad driving south the other day on I-57 when I was heading north. Was able to communicate clearly for about 6-7 miles on the 29. Is that good, ok, or bad?
  6. Turbo-T
    1,953
    708
    May 31, 2009
    That's good, especially if you're running the typical trucker fiberglass antenna that's usually only 3-4 ft. long.
  7. Treefork
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    Running a 4 ft firestik.
  8. mike5511
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    My favorite radio to run in the truck is the Connex 3300HP. Right now I'm using a 5ft Skip Shooter antenna.
  9. Turbo-T
    1,953
    708
    May 31, 2009
    Provided you're running barefoot and not running an amp, then yes you're doing good, since those antennas typically don't tx/rx that well. The antenna makes or breaks the radio. There's other factors too that play a role in how far you can get out....how high the antenna is up, SWR, terrain, if skip is rolling, if the truck is in the mountains, etc.
  10. Treefork
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    No amp, just a peak/tune on the 29. My dad has one of those Wilson antennas with the little beer can looking thing. Those any good?
  11. Freightshaker613
    Freightshaker613 Light Load Member
    74
    20
    Jan 5, 2013
    Ontario Canada
    Either a wilson 2000 or 5000. Both get the job done pretty well. I run a pair of wilson 2000s into a General Washington. SWR 1.2.
    Treefork Thanks this.
