Confused on GVW please help a rookie out!
Discussion in 'Freightliner Forum' started by PolishPrince, Feb 3, 2017.
  1. PolishPrince
    PolishPrince Light Load Member
    296
    69
    Jan 11, 2017
    Chicago
    SO im researching what truck will be fit my needs in the future and i know i will be trying to get heavy loads every now and again...
    I love the New Cascadia 126... but it lists the GVW at 60K lbs on freightliners website... does that mean it can only take 20K in the back with trailer? Am i understanding that correctly?
    And just FYI im at least 18months away from purchase...
  3. passingthru69
    Gross vehicle weight rating
    PolishPrince Thanks this.
  4. PolishPrince
    296
    69
    Jan 11, 2017
    Chicago
    Thanks for the response... can you break it down? Im still not following...
  5. PolishPrince
    296
    69
    Jan 11, 2017
    Chicago
    Oh think i understand... that the vehicle can maximum hold GVWR on it... so no more then 60k lbs sitting on the wheels? Please correct me if im wrong
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I have a Cascadia grossing 140,000 lbs pulling super b-train trailers.
    The 60k rating would be for a straight truck.
  7. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    It means the frame and suspension can hold 60k.
    But it really comes down to how you spec it out. Normal legal weight is 12k on steers, 34k drives, 34k on trailer tandems. On this setup, the tractor is only weighing in at 46k total.
  8. PolishPrince
    296
    69
    Jan 11, 2017
    Chicago
    SO 13,3k front and 40k rears would be a bit over kill but safe rating to haul heavy frequently...
  9. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    It is the amount the truck weighs and any load you have on the truck. Total of 60,000 pounds.
    60,000 minus the weight of the truck. Truck weighs, 20,000. Maximum weight you can carry on the truck would be 40,000.
  10. PolishPrince
    296
    69
    Jan 11, 2017
    Chicago
    Really appreciate it guys, think i understand now... Just trying to figure out what those new 2018 New Cascadia 126 with 72" Raised Roof can haul max payload...
  11. 123.Red Beard
    123.Red Beard Bobtail Member
    49
    37
    Jan 4, 2015
    Cochise County, AZ
    That 60,000 does not include a trailer ...
    If you get it spec'd too heavy, and only haul light or medium loads ... it will beat you to death ... in a standard class 8 five axle truck/trailer setup ... over 13,000 on the steer is overkill in my opinion ... I just got a '17 KW 680 with a 13,200 front, and 20,000 each drive (sometimes refered to as 40k rears) over 75k gross, it is not too bad, but still rough ... 50,000 gross is horrible! Not sure why boss spec'd it this way, as we rarely go over 50K gross ... ???
    Most interstates will allow you up to 20,000 on your steer axle, IF the axle, AND tires are rated for it ... some states restrict steer axle to 12,000 on their state roads, but not the interstate ...
    When you say you want to haul heavy ... does this mean over 80,000 pound gross (truck and trailer, plus load)? As this will usually mean you will need overweight permits in each state ... and possibly a special trailer ...
    Bean Jr. Thanks this.
