Compressor Unloader Valve Location On DD15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by iRookie, Dec 25, 2016.
  1. iRookie
    iRookie Light Load Member
    140
    174
    Aug 16, 2015
    Can anybody share a pic or point out where exactly is the air compressor unloader valve located on DD15. My system is purging every 60 Seconds "meaning the compressor is running non stop".
    No air leaks from the tank or airlines itself and I've already replaced the air dryer cartridge less then 3 months ago, thinking about cleaning carbon or replaceing the unloader valve fitting myself. Any feedback is appreciated!
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I know the location of unloader valve but honestly I don't want make you upset this Christmas day.
    tony97905 and iRookie Thank this.
  4. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    the valve is under cup. two small screws must be taken off to get to unloader valve. on DD15 once I tried to replace it and did not succeed. the air compressor must be taken off or the high pressure fuel pump. 5-6 hours job atleast.
    iRookie Thanks this.
  5. kitCat
    kitCat Light Load Member
    97
    38
    Oct 13, 2013
    It on top of the air compressor. Air compressor is located on the driver side right on the flywheel. You can change it without taking the air compressor out but it is going to a pain in the rear. Use small Allen keys to remove the two screw for the unloader. When installing the new one use a long screwdriver to push down the unloader valve and hold it, start one of the screws with a hand slowly. Good luck
  6. Espressolane
    16,967
    102,247
    Why do you think it is the unloader valve? Was the system purging like it is now prior. replacing the dryer cartridge? Something to consider, just because you replaced the dryer cartridge, does not fix the purge valve or heater element.
    While the cartridge is important, the rest of the dryer can be malfunctioning.
    Also have you considered the governor?
    Working on the air compressor on a DD15 can be difficult, it is mounted at the rear of the engine on the drivers side, off of the accesory drive. It has the power steering pump mounted to the end of the compressor.
    When getting into the compressor and other items running off the acessory drive, you really need to put things back together with new O-rings, seals, gaskets bolts and crush washers.
    You will end up with major oil leaks if things are not replaced properly.
    iRookie and mhyn Thank this.
  7. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    have you changed it on DD15 without removing the compressor?
  8. iRookie
    140
    174
    Aug 16, 2015
    No, but I had it replaced last year at the dealer "one hour labour but it took them 2 tries to diagnose the problem and 3 days to get to my rig". It's a very common problem with this part. The only reason I want to do it myself is to save time, learn along the way and avoid greese monkies screwingup my rig.
  9. iRookie
    140
    174
    Aug 16, 2015
    I service my air dryer every year regardless if there's a problem or not.
  10. Cecil.jonf
    Cecil.jonf Bobtail Member
    8
    7
    Dec 28, 2016
    The unloaded valve can be replaced with the air compressor installed. I have replaced them many times in the cascadias. It's a lot easier if you remove the left fender. If this doesn't fix the compressor running all the time, it is most likely the governor line running from the compressor to the governor. The line gets a hole in it causing it to leak. You will watch the air gauge build and you can watch it drain back down to governor cut in and then build again. It's a never ending cycle. Hard to diagnose cause usually you can't hear the air leak cause the engine has to be running.
