Company road test tips
Discussion in 'Questions From New Drivers' started by Goodguy88, Dec 17, 2017.
  1. Goodguy88
    Goodguy88 Medium Load Member
    470
    139
    May 8, 2017
    Hey dudes I finally passed an interview and I am going for company road test.
    Tips please
    And f u to the guys that said you need to start thinking about a new career, it isn't for you. This is Canada....and yes it is harder to get a job with limited expierence here on straight trucks because everyone prefers local. Its much easier getting a job tractor trailer
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Never done that myself. Maybe I'll ask for one.
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    mirrors, always keep the head moving, watch them mirrors, do not run over curbs, always have proper following distance and try to keep it as smooth as possible.
    Grubby, albert l and BillStep Thank this.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Most testers I've seen dopn't really care. Do a pretrip and mention anything obvious like an almost bald tire, or light out even if it's not required. Other than that usually it's as simply as not hitting anything.
    Goodguy88 Thanks this.
  6. pmdriver
    2,338
    3,503
    Nov 14, 2017
    Read the thread about Werner pooping himself, do not be that guy.
    Grubby and Texas_hwy_287 Thank this.
  7. TripleSix
    127,950
    Adding to this post:
    Seatbelt. Mirrors. Air pressure gauge. Transmission. Read EVERY road sign.
    When i did my road test, it was "turn here. Turn here. Turn here. Btw, what was the posted height of the bridge we went under a mile back? What's the posted speed limit?"
    Grubby, albert l, bottomdumpin and 2 others Thank this.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Stay on your side of the road and in the center.Do not weave all over the place.When making a turn watch the back tires so it clears the curb but at the same time you also need to focus on the traffic.Don't brake hard.
    Grubby and Goodguy88 Thank this.
  9. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    Wear a ball cap. I was given this advice from my instructors in school. Sometimes the test may not see your head rotate to check the mirrors. But if you wear a ball cap he/she will see it move and they will know you are moving your head for a mirror check.
    Grubby, TravR1, albert l and 2 others Thank this.
  10. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Most companies are looking to hire drivers, they don't WANT to turn you away. Nerves and anxiety can really kill people's chances. Also, don't lie about what you can do. If you've spent the last 10 years driving an automatic truck since getting your license, don't tell the person doing the road test you can drive a manual and then spend 20-30 minutes abusing the equipment.
    Secondly, do a good and thorough pre-trip. The tester should be telling you to move along, rather than you missing important things. I can't count the number of times I've had guys come in for a road test, and do about 75 seconds of walk around, kicking tires, checking lights and not even bothering to open the hood. It's like they think we just looking for warm bums to fill the seat, and not professional drivers.
    Bob Dobalina and Goodguy88 Thank this.
  11. Bob Dobalina
    Bob Dobalina Road Train Member
    2,578
    4,455
    Sep 20, 2015
    The "Buckeye"
    I used to give road tests to prospective drivers at a small local company and I can't tell you how many times guys didn't even check tires, let alone anything in depth. The company had bad equipment and even worse drivers (who'd gladly hand off a trailer with a flat instead of do a post-trip). I had to tell those guys "hey, you seriously need to check equipment out here; I find a flat tire about once a week."
    Some people think a road test is just to check to see if you can drive, but that's only part of it.
    Grubby and Zeviander Thank this.
