Compact Cb radio recommendations for new hot shot drivers?
Discussion in 'CB Radio Forum' started by Bran723, Jan 2, 2019.
  1. Bran723
    Bran723 Bobtail Member
    19
    Jan 1, 2019
    Good evening we are new hot shot drivers and are looking into getting a cb so if we need to get advice or help getting over on the road we will have it .What do you reccommend on getting? We are looking at a compact one thats got the radio built into the hand held speaker . Was hoping to not spend over $130-$150 if possible. Thanks in advance for the help
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I purchased a cobra 29 off of eBay quite a few years ago for $99, already praked and tuned.
    I then purchased a noise canceling mic for about $30 I think.
    Make sure to get yourself a good antenna, otherwise it’s just a waste
  4. Numb
    Numb Crusty Curmudgeon
    3,945
    8,780
    Jan 30, 2012
    Charlotte, N.Carolina
    A Cobra 29 is a good reliable radio. have had 3 in 34 yrs driving.
    throw the mike out the window. I use a cheap $10 one and it sounds better than the new one. lol.
    The antenna and cable are important. I use a Wilson and a good coax cable.cheap antenna and cable can make a high dollar radio sound like crap.
    stop buy a CB shop for advice on hook up.
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If it were me...I would stay-away from the handheld CB's like the Cobra 75's...If you drop it, it's done! Plus they just don't have that good of sound...
    Good cheap radio that is also small (4.5"W x 6 3/4" D x 1 3/8" H) would be the Uniden 520xl....You can pick these up for under $50....10X better radio than those handheld type...
    Meteorgray and shogun Thank this.
  6. Bran723
    19
    Jan 1, 2019
    Thank u. How do you know what type of antenna is a good one.
  7. Bran723
    19
    Jan 1, 2019
    How can i tell if the antenna is good? Do you reccommend a certain brand?
  8. Bran723
    19
    Jan 1, 2019
    Also do you think its worth getting the one with blue tooth and the weather updates?
  9. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I have a Wilson, but you can talk to guys at the CB shop and they will point you in the right direction
  10. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    I use several small compact CBs: Uniden 520, Cobra 19, Midland 1001Z. All of them work well for me and produce the legal 4W or less which, given a good antenna, communicate as far as the other legal radios.
    For more power, I attach an Italy RM 203P amplifier between the radio and the antenna, which boosts the signal up to 60 watts or more. This is enough to get good strong signals out there which can make a difference in some situations.
    I would stay away from the everything-handheld models. I've heard a lot of complains about their limitations regarding poor speakers, hard to manipulate in the hand, etc.
    Slowmover1 Thanks this.
  11. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,209
    Oct 25, 2015
    Fort Worth
    It’s a REALLY small budget. Make a start. Weather radio good idea. Bluetooth, no.
    I ran hotshot years ago in South Texas oilfield. Your trucks, or someone else’s?
    A digital UNIDEN 980 AM/SSB (look up single sideband) is the lowest priced radio I’d want to recommend ($120) as spending more won’t get a lot more.
    But you’ll want an RM ITALY 203 amp, ($75) and a WEST MOUNTAIN RADIO CLEAR SPEAKER ($199) to go with it for best performance (good or better than many/most “big” radios). 70W kick and the speaker cuts out noise & static. And will all run off a 15A circuit.
    The antenna is always key. For a pickup (not yours) a WILSON 1000 or SIRIO 5000 ($100?) magnet mount. For a truck I own, a puck mount.
    Get a decent little radio then save towards antenna. A total of around $500 will allow you to HEAR, and BE HEARD.
    Look up radio mounts to fit truck. GENOS GARAGE sells mounts for a Dodge one ton like mine. In the meantime, get a luggage strap to attach to seat console.
    jdsilver7531 Thanks this.
