Common 06 d12 problems?
Discussion in 'Volvo Forum' started by Thetrashnoob, Mar 8, 2021.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    262
    45
    May 30, 2019
    I just came across a 06 Volvo tri axle dump truck that caught my intrest. It has the d12 motor, with a 18 speed, just over 300k miles. Any common problems with these motors?
  3. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    I have a d12d in my 06 vnl780... 1,397,000 miles. Had to do the turbo at 700k and injector cups at 1,100k (still has the factory injectors) other that running the overhead every 150k it's never had any work done
    Thetrashnoob Thanks this.
  4. Thetrashnoob
    262
    45
    May 30, 2019
    Truck looks real clean, just wasn’t sure about the motor. Around here it’s all kenworth/Pete or Mack. Not a lot of Volvo’s
  5. flood
    4,157
    4,020
    Dec 25, 2010
    Dump trucks are harder on the drive train, my dealer told me the d12d is about as bullet proof as they come...
    Only downside is only volvo or mack can work on it
  6. Thetrashnoob
    262
    45
    May 30, 2019
    That is true, but same thing only paccar can work on paccar etc. but it is something to consider
  7. 401-Alex
    401-Alex Light Load Member
    258
    278
    Nov 25, 2013
    401
    I have an 05 volvo vnl670 D12d. 13spd. 1.6 million still going. Low mpg but starts everytime as far as i know its on original internals including injectors. Not sur if a new set will bring up the mpgs. Egr valves can be a problem on this motor if it has a has an OTR kit to Fix them then it should not.be a problem. Otr doesn't make kits anymore fyi
  8. Death Hauler
    Death Hauler Bobtail Member
    31
    8
    Jul 6, 2017
    Its a great engine. When I was a company driver I drove a D12 volvo for almost 150K miles and the only thing that went wrong was the air compressor started leaking coolant into the air system. I bought a 06 volvo myself afterwords and became and owner operator. It currently has 1.2 million miles and still running strong. I also had the air compressor problem so that got replaced, 1 injector went out, i had to replace the fuel pump and accessory drive, the fuel filter housing has a tendency to leak air into the system so i replaced that, clutch fan went out at around 900K. The engine itself is doing good though, i will warn you if you have a egr code for faulty egr system it will derate the engines power and the truck will be slow, it will still run but its going to be slow.
