coming to a stop downshift or just put in neutral?
Discussion in 'Questions From New Drivers' started by Aarrons, Oct 3, 2016.
  1. Aarrons
    Aarrons Light Load Member
    242
    75
    Jul 13, 2015
    Lets say you come up to 7th gear and a stop is ahead in a city with multiple stops do you have to downshift all the way to 1 o 2 or just put in neutral from 7 and go up all the way from 1 or 2 of course remembering to flipping the selector. and repeat this process in all the stop signs.
    thanks
  3. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    If you travel farther than a truck length, you're "coasting" which is illegal in most states. You'll flunk your driving test in every state if you don't keep it in a gear except for the brief moments it takes you to shift. In other words, you downshift. Every time.
  4. Aarrons
    242
    75
    Jul 13, 2015
    Do I have to downshift all the way to 1 or 2 before the stop, or can I stop lets say in 6th, then put in neutral
  5. amiller
    amiller Medium Load Member
    475
    249
    Nov 26, 2012
    Charlotte, NC
    No you don't have to downshift to a complete stop. Do what you're comfortable with
    JReding and Chinatown Thank this.
  6. TripleSix
    127,988
    7th gear, brake and scrub the speed down...let the rpms drop...downshift to 4th or 3rd. You do know that you can skip gears, don't you?
    Btw, Bulldog' dead on about the regs.
  7. breadtrk
    breadtrk Heavy Load Member
    788
    823
    Oct 4, 2015
    Never coast to a stop. Last truck length ok, but never ever more than that. PERIOD!
    Ever.
    G13Tomcat Thanks this.
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Coast.........(just not on a driving test)
    JReding, RedRover, Chinatown and 5 others Thank this.
  9. AModelCat
    154,536
    Uncontrolled stop if you coast up with clutch in or trans in neutral. I've only ever driven 18 speeds and when I do drive I never bother with the splitter on downshifts. I'll bring it down to 4th direct on the low side, then once the RPM's drop down to idle, I'll step on the clutch and stop. Then shift into whatever starting gear I'm going to use.
  10. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    I down shift and brake until at 10 mph. Hit 10 mph go to neutral and brake the rest. Helps the brakes too to use the gears to slow you down.
  11. Blackshack46
    Blackshack46 Road Train Member
    @Pedigreed Bulldog @TripleSix
    I was coming down a slight grade today and at the bottom is a light. I go through this light everyday at least twice, sometimes more. I understand what makes the light trip.
    Well coming up on it I seen it change from red to green, I said ok, i got time. Unfortunately it turned back to yellow red as I was maybe three truck lengths away. No time to down shift from 9th. So I pressed the clutch and gave it a good controlled braking and stopped before the brake line.
    I'm not worried if this is correct or not, just curious if this is illegal according to regs.
    Yes yes I know I should have expected the unexpected and should have been prepared for it. It was literally a "hey! Why is my head up my arse?"
    The second time around I was ready for that sob. It's off on its changing today.
    I'm pretty sure I answered my own question. What are your thoughts? Experiences?
    TripleSix Thanks this.
