comfort pro apu no heat no ac no fan but panel is on and apu starts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jimkas, Jun 9, 2023.
  1. jimkas
    jimkas Bobtail Member
    7
    My APU comfort pro unit turns on and everything well, but when I click AC or HEAT or FAN inside the panel nothing turns on or works and it stays at the main screen. Any1 knows why or how to fix it? thank you
    volvo vnl 670 2016
  3. Arctic_fox
    3,864
    19,461
    Sep 16, 2016
    Check fuses first and formost. To me it sounds like something went pop. If that doesnt fix it check that the pannel hasnt come unhooked or loose somehow.
    Beyond that im not great with carriers so id take it to a dealer.
    Siinman and jimkas Thank this.
  4. jimkas
    7
  5. jimkas
    7
    yeah, the panel works and it starts the apu outside but once i click any function outside of menu etc it doesnt kick anything on and it just kinda refreshes and goes back to the main menu.
    u mean the board hvacs relays or the fuse outside at the APU side ? ive checked 1 glass fuse at the board and its fine the rest are all relay box fuses.
  6. angel8492
    angel8492 Bobtail Member
    I have the exact same problem, let me know if you fix it
  7. joec214
    joec214 Bobtail Member
    Did anyone figure out how to fix this issue?
    I'm having the same problem. APU starts, but nothing happens when I push the AC or Heat button. Just stays on main screen.
  8. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Same here. About to give up on the whole thing and have it removed. Company truck, let it idle.
  9. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    The A/C fan must have a relay. Check to see if power is getting to the relay when A/C is on. If yes, see if power is getting past the relay. If no power to relay, trace back from there, you'll need a wiring diagram.
    This of course is if you want to save some coin and try to solve the problem yourself.
    joec214 Thanks this.
