Comfort Master APU: Check oil switch?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hiallz, Sep 4, 2011.
  1. hiallz
    hiallz Bobtail Member
    13
    I bought a comfort master APU not that long ago and it was working fine, but now it brings up a message on the monitor telling me to check the oil switch. I tried changing the oil and it still has the same problem. The sequence it starts up showing is:
    Preheat
    Cranking(stays in cranking longer than usual)
    *beeps* Check oil switch
    It should be like this:
    Preheat
    Cranking(for about 5 seconds)
    *beeps* Running
    What could be the problem?
  3. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    if oil level is OK It maybe some other reason it will give you same code .I have the same unit. You could down load the owner manuel on line I did it.
  4. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    I don't know anything about this, which of course has never stopped a truckdriver in the past :biggrin_25524:, but is there some kind of a reset switch or process to do when you change oil?
  5. hiallz
    13
    I don't know if you have had experience with a Comfort Master APU before, but do you know any way on how to reset it?
  6. Hardlyevr
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    my experience has only been with ThermoKings, but they have a reset button on the side of the black box that they usually locate in the sleeper side box above where the unit is mounted. Any time a fault shuts the unit down, the reset button must be pushed to get it to start again.
    The ThermoKing also has a shut off toggle switch under the units cover, so that a mechanic when working on it, doesn't have to worry about it starting up. If it is left in the off position, or bumped off, the unit won't start, much like what you are saying. But again that's on ThermoKings.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    If it says check the oil switch, it probably has an oil pressure switch as a safeguard. Look for a sensor on the block. It either works on a 5V reference signal (2 wire) or a ground signal (1 wire) back to the units ECM. It could even be a bad oil pump, but I would focus on the switch first. You could check it with a digital volt/ohm meter. I've even seen oil pressure switches get trash in them making them inoperable.
    Just because it's fairly new doesn't mean you can't get a faulty part. Is it still under warranty?
    Let me go do some research on your unit and I'll be back.
    BigJohn54 Thanks this.
  8. CondoCruiser
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Not having much luck. Comfort Master went out of business and their website is suspended. But it looks like you can get parts and service at independent shops.
  9. johnp
    johnp Bobtail Member
    6
    Oct 2, 2011
    have you found the problem with your comfort master yet? i have the exact same problem. i have swapped out pdms, cabin controllers, oil switches, alternators (tach reading comes from alternator), and now i am checking every inch of wiring to see if there is a break in something. i have also changed software versions and that hasent helped. let me know what you find. i will also let you know if i find anything. thanks
  10. Jigsaw
    Jigsaw Light Load Member
    83
    91
    Oct 12, 2010
    Colorado Springs, Co
    If it shuts of immediately, it is the electric fuel pump. It is a Mr. Gasket fuel pump. You can purchase these at most auto parts stores. If it starts and runs for about 30 seconds before it shuts off, the oil is too thick. Summer time run no heavier than 20/5 wgt. winter time run no more than 10/5 wgt. Jusy cause it says Check Oil Switch, you will find out it has nothing to do with the oil switch. If that doesn't work,about the only place left that can help you and get parts is Tim's Mobile Repair in Colton, Ca. Talk to Bruce or Tim. Most of the time if you tell them what the problem is he can tell you the solution. Yes I have one of these pieces of crap.
  11. johnp
    6
    Oct 2, 2011
    turns out the alternator was still the problem. the replacement i got wasnt self exciting so the tach signal wasnt being sent out. i have another on order and that should fix my problem. thanks jigsaw
