I noticed in the CDL practice test section there is a test for COMBINATION VEHICLES and another for DOUBLES/TRIPLE TRAILERS. What's the difference? Is a double and triple not a "combination vehicle?"
Also, I saw someone who posted something to the effect that new drivers don't have to worry about taking these tests because they're prohibited from driving combos or doubles/triples for at least a year. Can someone elaborate? I've been studying all of the tests and figured I'd test for all of these endorsements when I test. Is this a good plan or should I wait on the combos and doubles/triples testing until later down the road?
Combination vehicles/doubles
Discussion in 'Questions From New Drivers' started by 900,000-tons-of-steel, Sep 10, 2012.
Page 1 of 3
I've never heard the ruling of needing a year.Of course I took my 1st CDL test back in '98.When I did, I took the doubles/triples, and Haz-mat all at the same time.What they mean by other combo, vehicle,can be any vehicle that has two parts or more. i.e. tractor and (one ) trailer is a combination vehicle.
900,000-tons-of-steel Thanks this. -
Combination vehicle is any truck and trailer.
Could be a tractor pulling a semi trailer or a dump truck pulling a small flatbed with a backhoe on it.
Doubles and triples, as the names imply, are pulling more than one trailer.
There are more things to consider when dealing with doubles and triples so they require separate endosement from simple truck/trailer combination.Last edited: Sep 10, 2012
A truck and trailer is a power unit that also holds cargo and then pulls a trailer. The other is just as it sounds. You don't see hardly any truck and trailers in the east but out west they are used a lot in the gasoline business. In my state a combination vehicle is all of them, tractor with a semi trailer, or any combination.
900,000-tons-of-steel and otherhalftw Thank this. -
So the COMBINATION VEHICLES is needed before one can pull any trailer since the tractor and (one) trailer is a combination vehicle? What does taking only the GENERAL KNOWLEDGE portion qualify one for after taking the road test?
General knowledge would get you nothing. Maybe a straight truck with no air brakes but i think theres another test to take.900,000-tons-of-steel Thanks this. -
Each state is different. I have a passenger endorsement but it is for class C vehicles. Doubles/triples. I have that endorsement also. Fed Ex hires students and you drive as a team. Driving doubles and triples is a lot easier then you would think it is. And in the winter on ice and snow, they almost park themselves. Watch sometime at how many of them find the ditch all by themselves.
To pull a B truck with a trailer behind it you need a combination vehicle endorsement. If there are air brakes involved, you need an air brakes endorsement. The Class A CDL contains air brakes and combination vehicles. To actually pull doubles, you need to have part of your brain removed. One driver pulling two trailers means one driver is unemployed and the other nut is doing his job for free. That is of course my opinion. But it is correct.900,000-tons-of-steel Thanks this.
Page 1 of 3
