My hood looked like it started to separate on both sides near the hinges/headlights. So a few months back, I took it off, sanded the area down, poured some resin in the openings, clamped it, and did a wet fiberglass layup repair on the area. It worked great and hasn't budged there since. But now it cracked in a completely different spot. This time on the outside under the left headlight. This will be harder to repair but not impossible.
So I just wanted to see what others do. Do you guys just keep repairing it or has anyone come up with a more permanent solution? I'm almost temped to cut out metal plates, one long one across the outside, and two or 3 inside and just run bolts through it. I think I can still make it look decent with some smooth chrome or painted bolt heads or something like that. Any other ideas?
Columbia hood cracking near hinges. Any good fixes?
Discussion in 'Freightliner Forum' started by dlstruck, Dec 31, 2016.
When I have seen fiberglass reinforced it was with wood. The wood absorbs some of the resin to help stiffen the repair.
I have not had this problem with my hood. Post what you did for a repair. Or did you just replace the hood?KB3MMX Thanks this. -
You might have a different reason for your hood cracking. If you put a different one on, it may crack also.
Something is causing the cracks. Bad mounts. Hinges ok?
I've had to repair the hood under the headlight bucket passenger side. Just used some mesh and residential. Small Patch. Hasn't cracked yet.
Good luckKB3MMX Thanks this. -
xsetra Thanks this.
Here are the pictures from the first time I fixed it. As you can see, it now cracked right at the edge of my repair. Originally both hinge mounts were glued with some sort of adhesive that separated from the fiberglass. Luckily my dad did auto body for 20 years and had some boat repair experience so he helped me out with a quick fix to get the truck on the road. It wasn't pretty but it worked.
The new crack doesn't look too bad but it's actually putting a lot of stress on a thin part of the hood.KB3MMX Thanks this. -
I just took the hood off again and I'm having my dad fix it. He sanded down the original repair a bit to add more layers and cover a larger area. I'm not going to have him fix the outside just yet because freight is paying really well right now but structurally it's much better and that will be next.
Once I get a slow week, I'll have him grind away on the outside and layer a repair about 12" in each direction. I'll update with more pics as he gets further along.
Looks like a major (minor) repair.
Good luck.KB3MMX Thanks this. -
I have had a few of these come into my shop. I came up with a metal bracket that goes inside of the structure. I fabricated some steel plates that bolt on to the hinge plates and run past the hood strap bolts. The owner of the trucking company called and said the driver had hood open and a strong wind caught it and it held up.
Reason for edit: Removed phone numberKB3MMX Thanks this.
