cold weather idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Feb 2, 2013.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I hear different responses. I start my truck start of the day. it goes right to 900 rpm's, it gradually lowers. is there a set rpm I should keep it at, if I have to idle? should idle be the same no matter if coolant temp is under operating temp or at operating temp? I have been letting the idle go from 900 & set it at 700 when it drops to that point. ser 60 ddec 3.
  3. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    I'd idle at 900, nearly all mechanics I have met would tell you that or even higher. Slow idling starves the turbo bearing of oil pressure and causes other problems. Identical 12.7s; one I ran, one with fast idle disabled, the turbo shaft broke in the one that wouldn't idle, and road service drivers have told me the broken turbo shaft is something they don't like about the Series 60. The one I was stuck with was still going on the original at 1 million miles.
    Cummins ISX manual said to idle it at 800 rpm, DD15 at 900 RPM; Acert Cats were not supposed to be slow idled for any length of time, either.
    bullhaulerswife and heavyhaulerss Thank this.
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    if I idle my truck, it's because it's below +5*F. The bunk heater just can't keep it warm enough it seems that cold.
    When I do idle for extended periods, it's at 900 RPM.
    You get poor oil distribution, generator isn't kicking out enough amps to keep everything charged and fuel dilution of the oil at curb idle.
    heavyhaulerss and Koolk Thank this.
  5. MNdriver
    7,985
    4,371
    Feb 24, 2012
    If you start to see drool coming out out of the stack, it diesel slobber and you need to idle up.
    Your engine is running too cold.
    SHC and SHO-TYME Thank this.
  6. Bumpnrun
    Bumpnrun Light Load Member
    181
    82
    Jul 29, 2010
    Petoskey, Mi
    I'm currently in Northfield, Mn and have to idle for the first time this season. I'm in a Volvo w/ a Cummings in it and idling @ 600 rpm's...so this is bad?
  7. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    Is your coolant up to running temperature? That is the first question. If you have an operators manual it should be in that.
    If you can bump up the idle, it should go to a setting of maybe 800 or 900 rpm.
  8. MNdriver
    7,985
    4,371
    Feb 24, 2012
    Your engine is not going to generate enough heat in this cold to keep the fuel all burnt. You'll evaporate it out when you leave again and get everything up to operating temps.
    It will also only get up to about 150 * too.
  9. Bumpnrun
    181
    82
    Jul 29, 2010
    Petoskey, Mi
    My operating temp is at 175 but had no clue about the fuel issue...and here I was thinking it was pretty cool I use less than a 1/2 gl an hour idling. But if I need to bump the rpm's up, so be it. Thanks!
  10. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    When the company gave me a '09 KW the other drivers had already been talking about needing to idle up to 900 rpm's. After four months a mechanic asked if I'd been to the KW shop? During this time the truck had not giving any signs of trouble, but he said that truck was a regular to the shop during the previous year, mostly with DPF issues. The Cummins rep. has told the company to have us idle up to 900 for several reasons including maintaining a higher temp for keeping the exhaust cleaner.
    MJ1657 Thanks this.
  11. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Remember, a diesel engine fires from heat and compression, if it is too cold, it doesn't get complete burning of the fuel. Which, in turn will lead to fuel in the oil, carboned up turbo and moisture in the exhaust which can lead to corrosion in hte exhaust system. IF you walk through a truckstop and see trucks with what looks like vapor coming out of the exhaust, they aren't running hot enough.
    I used to do this when I drove a Mack day cab for the one company, I kept a piece of cardboard in the cab, when I had to idle it at night while I was in the hotel. I would put the cardboard over the grille to help keep heat in the engine and idled it up about 1200 rpm. I never had a problem with diesel slobber.
    bullhaulerswife Thanks this.
