Coil racks
Discussion in 'Flatbed Trucking Forum' started by G R Ginther Trucking, Apr 15, 2017.
  1. G R Ginther Trucking
    G R Ginther Trucking Bobtail Member
    How short can my coil rack lumber be. I want to store them on top of my side box and it is 60 in.
  3. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    I have coil rack beveled lumber that is about 5 feet. Plenty long enough to support the coil, and short enough they don't get in the way of the chain tie-down locations. I load most of my coils eye to the side. I think the lumber needs to be just long enough to distribute the weight so it's being carried on the frame rails. 50-60 inches so it'll fit in your side box is plenty.
  4. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I have 4 pieces that I store on my headache rack that are only 4ft long. I dont do a lot of coils, maybe 4 - 5 a yr. But in the last 2 yrs,.. all I have ever used are the 4ft boards.
    Hurst
  5. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,674
    12,737
    Dec 15, 2014
    Charlotte, NC
    You back at it now
  6. Chewy352
    Chewy352 Road Train Member
    1,797
    11,619
    Dec 17, 2013
    Enid, OK
    Mine are about 5 foot long and I've had 7 foot coils on them with no problems.
    Hurst and DDlighttruck Thank this.
  7. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Back at what?
    Hurst
  8. Espressolane
    17,607
    107,996
    Carried 6 to 8 short boards, I liked them to be 5 ft (60 in.)
  9. Gunner75
    Gunner75 Road Train Member
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    I have 4 ft boards for my coils, my 8ft timbers only get used for load support for anything but coils
  10. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I don't have much problem with 4' coil timbers. So far, anyplace that wants them longer wants 8' ,and two 4's won't work.
  11. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    60" will be fine. I don't care for anything shorter because a lot of coils are coils are 48" or wider and if they load with a c hook or moose and set the coil down on an angle it can kick the wood out of place. You either have to get it lifted up again and straighten the wood or you'll see guys chain it down like that. Not really the safest thing. If the wood hangs out a bit you can usually hit it with a sledge and it slide out to the rack where its supposed to be.
