Coffee maker on 1500 watt inverter, will the inverter handle it?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by BBall735, Feb 10, 2019.
  1. BBall735
    BBall735 Bobtail Member
    My 1500 watt inverter can't handle my coffee maker.
  3. Nukem
    Nukem Road Train Member
    1,237
    1,447
    May 11, 2014
    pretty vague is an understatement
    Umm... What kind of coffee maker? Inverter? what kind of truck? Is the inverter wired correctly?
    Edit: Do you have an APU?
  4. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    Idle the truck when making coffee...That might work for you.
    88 Alpha and MidWest_MacDaddy Thank this.
  5. MidWest_MacDaddy
    11,277
    19,164
    Feb 21, 2015
    South Carolina
    Ya, I have to idle my Truck when running my microwave when heating water for my coffee.
    Omega1 Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    We used a 2500 watt continuous with about a 3500 surge with a 10 dollar 1000 watt Mr Coffee Pot. No problems.
  7. spyder7723
    spyder7723 Road Train Member
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    A 1500 is pretty weak for a coffee pot. The heater element in the pot draws a lot of juice.
    flood Thanks this.
  8. Nukem
    1,237
    1,447
    May 11, 2014
    I have a 1500W inverter in my truck. It powers my microwave (700w), my Keurig (1500w initial start, 700w brew), and George Forman compact grill (760w) with no problems. But I also have an APU so it kicks in when needed. I also don't have a lot of 12v stuff plugged in and I have my laptop charger in the inverter when I'm using it with one of the above.
    Hence why I was asking questions...
  9. snowwy
    snowwy Road Train Member
    20,587
    13,307
    Jul 6, 2009
    Someone once mentioned. YOu need to know the wattage the appliance runs. Then double that for the invertor.
    Gotta remember there's always a power surge when first kicked on. 1500 might not be enough for that power surge to kickstart that puppy.
    There's also the dillema that some appliances won't run on dirty power and you'll need a digital sinewave invertor to solve the dirty power problem.
  10. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    How old is the inverter? They tend to get weak after a while, a year and a half or so. Maybe that's just the cheap ones.
    Batteries ok?
  11. spyder7723
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    A good quality one will last decades. I got a 2500 watt out of an ambulance in a junk yard 15 years ago and its still running strong.
