Code SPN 520761 FMI 5
Discussion in 'Freightliner Forum' started by Lirencao, Nov 11, 2020.
  1. Lirencao
    Lirencao Bobtail Member
    7
    Good Evening all !!!!
    My Freightliner Cascadia has a code, but I don't find its explain in software help, who know it pls tell me.
    SPN 520761 FMI 5
    Axle Temperature Center Trans Temperature Feedback - Current Below Normal Or Open Circuit.
    Where is this sensor?
    Goody
    Mark
    2020-11-11
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Axle temperature sensor is mounted on the back of drive axle housings in the center where the differentials are and in the lower part of the housing so they are in the oil. The wiring harness might break right at the sensor connector, this happens especially when the wires are not secured properly on the axle housing. Or I have seen wires chaff against the axle housing, again because they were not secure properly.
  4. Lirencao
    7
    THANK YOU very much!!!
