So I purchased a Cobra cb...(29 LTD)! I'm not one to talk much but I must admit it can get very comical at times. I mainly purchased it for traffic, accidents, police and things like that. Also the past few days I'll be runnin in a pack and for some reason when the radio waves are buzzin it just makes me wanna turn the wheels! Lol... that being said I don't get very much reception if we're not close. Shall I upgrade antenna? Don't know much about them and don't wanna spend crazy money. Any input would be appreciated!!
Cobra 29 ltd....antenna????
Discussion in 'Questions From New Drivers' started by seventhirty, Jun 4, 2017.
Page 1 of 3
How much is not much, and how far do you expect to get?
And no matter what anyone tells you - don't mount the antenna at a 45 degree angle like so many do.
They seem to think that the radio waves shoot out the top and that it will get them more range - like a water hose.
The waves propagate parallel with the antenna along its length. If it is angled down, where do you think the waves will go?
The most important thing with the antenna is the SWR (Standing Wave Ratio).
The closer you can get it to a 1:1 ratio the better.
The Cobra has a meter built in that lets you check it. Learn to use it and adjust your antenna to get the best possible ratio. (That means you need an antenna that can be adjusted, if the OEM antenna is not adjustable and the ratio is more than around 1:1.2.)tscottme, KB3MMX and seventhirty Thank this. -
seventhirty and KB3MMX Thank this.
G13Tomcat Thanks this.
My XM radio antenna is mounted to it, and it is vertical. There is room on it to also mount a CB antenna.seventhirty Thanks this. -
Most good cb shops will charge around 40 for a good tuneup, what they call a tweak and peak.
Most radios are set at 4 watts out of the box, but you have to realize, in most cases these are machine tuned with some variables.
A good shop will test them with an oscillator to make sure they are transmitting and receiving the way they are supposed to.
Once that is done, the fire sticks are ok, but I prefer the 5/8 wave if I use a fire stick.
Another good choice is the Wilson 2500 or 5000.
Once the radio is properly tuned, it's much easier to set a proper SWR.
I run the Cobra 29 Chrome LMTD with a Wilson 2500.
My SWR is running right at .06. My out put is between 4 and 5 on the meter and my range depending on weather, location, and atmosphere is anywhere between 3 and 10 miles.seventhirty Thanks this.
Page 1 of 3
