Clutch possible pilot bearing or broken spring advice
Discussion in 'Ask An Owner Operator' started by Edjahman, Nov 1, 2018.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hi.
    What do you all think about running a clutch that just makes very little racket when you are engaging it?
    I can feel it in the pedal when I let it out and it's not loud or grabby or anything. It's a low humming kind of sound. It's difficult to describe.
    Peterbilt is saying possible pilot bearing or broken spring....they don't really know.
    Could it go out at a really bad time and should I just deal with it if my money is OK?
    I'm getting rid of the tractor in 5-6 months, that's why I ask.
    Thank you!
    tommymonza Thanks this.
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,822
    Dec 7, 2015
    OK
    Well if the pieces of spring get wedged in the right spot your clutch won’t disengage.
    Dave_in_AZ, magoo68 and Edjahman Thank this.
  4. Diesel Dave
    8,526
    23,524
    Jan 20, 2010
    Hesperia, Ca.
    Grease the throw out bearing and see if it quiets down a little.
  5. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    probably broken diaphram spring if feeling in pedal This does not sound like an emergency.
    Edjahman Thanks this.
  6. Cam Roberts
    1,621
    1,938
    May 13, 2018
    he says " when he lets it out" un greased throw out bearing would have issues soon as you push the pedal in and hold. He is saying its having issues when torque is applied to clutch and input shaft upon engagement. i think he might have diaphram spring broken
    Edjahman and Diesel Dave Thank this.
  7. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    There is no funny feeling or funny noise that is going to Get u by for me 5 months
    Noises and feelings are warnings of Fix my szz NOW or be Stranded
    stillwurkin and Edjahman Thank this.
  8. Edjahman
    648
    444
    Apr 2, 2013
    Thank you for your replies!
  9. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    Ever saw the damage from a clutch and flywheel that blows up and comes through the bell housing? It not very pretty. I know where 2 trucks sit that this very thing happened to... One is very old and is just a rust bucket now, but pieces of the flywheel and clutch came up through the bell housing AND floorboards. The other is a mid 90s Pete and it has similar damage as the first, but nothing came clear through the floor boards... But it sure dented the floor upward several inches.
    If I were you id get it fixed. Just my $0.02
  10. Cam Roberts
    1,621
    1,938
    May 13, 2018
    oh the sky is falling post. Here we go. you saw 2 of them do this. thats bs. This guy will be fine. clutch isnt gonna come apart and go through the bellhousing and floor board like a top fuel dragster at 10k rpm and 10k hp.
    Big_D409, BigCam9670 and Edjahman Thank this.
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I have seen clutch disc pads wear and allow the clutch hub to scrub on the flywheel bolts. Also if worn to the rivets can do this. Both stop after the clutch fully locks in.
    A clutch job on the road broke down can be very costly.
    Dave_in_AZ, Diesel Dave and Edjahman Thank this.
